Tracker noise
  • 2664 Views
Offline bkcraun
  • 22
Tracker noise
« on: June 20, 2004, 04:41:14 AM »
OK men, I need your help.  My 1998 Tracker is making a funny clicking noise up front in two wheel drive.  The manual hubs are turned to Free.  If I switch it to 4 wheel high, the noise goes away, again the hubs are still Free.  The noise is pronounced going forward or in reverse in 2 WD.  The clicking noise gets faster as the vehicle goes faster.   Like a rock in your tire noise.  My first thought is a bad birfield, but they aren’t engaged in 2 WD are they?  Any ideas?
Re: Tracker noise
« Reply #1 on: June 20, 2004, 07:19:12 AM »
The only time I've had a clicking noise is
front, is in 4WD and hubs engaged, it sounded
like a roller coaster clicking as you get ready
for the first drop.
I was thinking tho, are you sure the hubs are
not stuck in the engaged mode, and the CVs
are clicking from wear ?? while going forward,
Other than that, a bad U-joint does make
some clicking sounds too.
Hope this helps
Offline 90Stomper
  • 427
Re: Tracker noise
« Reply #2 on: June 20, 2004, 03:23:50 PM »
im betting on the u joint, check that your front shaft is really disengaged too.  next bet is the hubs too.  never had your problem but i have had 2 trackers that got so crappy that they would not engage, and when i took them apart the springs were weak!  might not be 100% holding them in, if stock hubs the spring pushes and pulls the locking ring in and out...
you did look for rubbing stuff..... and that rock right? ;D
2004 chevy tracker, 4door, V6
says 'Chevy' on the outside,
Offline bkcraun
  • 22
Re: Tracker noise
« Reply #3 on: June 23, 2004, 06:50:11 AM »
Gonna find out today.  Had to put the Tracker in the shop because I had a control arm bushing that the bolt had frozen up in.  I found this out as I was trying to install Calminis steering stabilizer.  While the shop has it,
I'm going to have them put on a set of Warn premium hubs.  Hope it was just a hub, I'm running low on moola.
Offline bkcraun
  • 22
Re: Tracker noise
« Reply #4 on: June 24, 2004, 05:25:08 AM »
It was a bad hub.  Got those bulletproof Warns on now!
Re: Tracker noise
« Reply #5 on: June 24, 2004, 03:25:44 PM »
Watch the hub bolts, they work loose, they
are not "cone washered" like the stockers,
that and you could have saved the $100 on
the new hubs by cleaning the old ones, save
the old hubs, just in case you find the new
hubs to be less than you expect
Offline bkcraun
  • 22
Re: Tracker noise
« Reply #6 on: June 25, 2004, 01:52:05 AM »
I'm only running 235's.  I don't think they would be large enough to cause hub bolts to loosen?  I also have this "shield" that goes around my hubs.  I can't even see my hub bolts to see if they are coming loose.  Should I remove that shield?
