BEST Gear ratio for diffs
  • 9 Replies
  • 3459 Views
Offline ColtonP
  • 147
« on: September 07, 2010, 01:49:30 PM »
Want to run some lower gears but don't know what to get or where to get them idk if its possible but I want to be able to spin 32s on dry pavement that's the torque I'm looking for.  95 tracker 1.6 16v any suggestions it is my DD
1987 Suzuki samurai BONE STOCK
(SOLD)1990 Samurai 1.6 8v swap, Arb front air locker, spool rear, RRO coil suspension, Chromoly front axles, 33x13.5-15 Swampers, ARB Bumpers, Slider, fender flares, 6.5:1 transfer case, True beadlocks, 1.5" wheel spacers,Roll cage. All in all a lil over 10k in parts uuuggghhhh!!!!!(SOLD)
(SOLD) 2000 Chevy tracker, 4 door, 4x4, auto trans, 2 inch lift,265/70r16 (SOLD)
(TOTALED)1995 tracker lsi, tintop, 3speed auto trans, 2 inch lift, 2 1/2 inch exhaust, 30x 9.5 bfg a/ts, custom front bumper.(TOTALED)
Offline Jluck
  • 1389
  • 40
Re: BEST Gear ratio for diffs
« Reply #1 on: September 07, 2010, 02:02:03 PM »
you could get some 5.12's from a four door. you probably should get the axles too, sounds like you will need them. whats the point of spinning 32's on dry pavement? might should trade the tracker for a v8 powered something ;)
Offline ColtonP
  • 147
« Reply #2 on: September 07, 2010, 02:05:39 PM »
Not wanting to smoke the tires or nething just want to pull up to that rock over there and not have to hold it to the floor to get it to crawl up it wat year 4doors got the 513s
Offline ColtonP
  • 147
« Reply #3 on: September 07, 2010, 02:07:08 PM »
Ment 512s
Offline Jluck
  • 1389
  • 40
« Reply #4 on: September 07, 2010, 02:13:14 PM »
most years (all that I have found) I have a few extra sets. where are you located?
Offline ColtonP
  • 147
« Reply #5 on: September 07, 2010, 02:23:45 PM »
Virginia and I do a lot of rock crawling with my friends and just need more torque to my tires
Offline ColtonP
  • 147
« Reply #6 on: September 07, 2010, 04:19:42 PM »
Are they direct bolt ins as though I just pulled my diff out and put it back in
Offline Jluck
  • 1389
  • 40
« Reply #7 on: September 07, 2010, 04:41:20 PM »
yep, tracker/sidekick axles are the same.
« Reply #8 on: September 10, 2010, 03:47:04 AM »
What you really need is a set of tcase gears, the 4.3 to1 which will give you all the crawling and climbing gear you need. Trail Tough and Calmini both have them.
Offline ColtonP
  • 147
« Reply #9 on: September 10, 2010, 04:30:03 AM »
Wayyyyyy to expensive for my blood that's y I want to start with some junkyard diffs
