where to find kicker 3 info
  • 9 Replies
  • 3361 Views
Offline SiKiD_01
  • 574
  • Fully Sik, Flying Vit.
« on: June 02, 2005, 04:53:22 PM »
any pics, links, info on the kicker 3?
thanks
steve
Offline safarikick
  • 270
  • nor-cal rhinos
« Last Edit: June 02, 2005, 05:05:59 PM by safarikick »
Offline 92Sidekick4x4
  • 1456
Re: where to find kicker 3 info
« Reply #2 on: June 02, 2005, 05:20:22 PM »
how does the kicker 3 work again?
Offline zukin
  • 54
« Reply #3 on: June 02, 2005, 05:22:49 PM »
Offline SiKiD_01
  • 574
« Reply #4 on: June 02, 2005, 06:34:50 PM »
thanks guys.
now if only i could get it in australia, i'd be set.
OTT say you need to send them both transfers. man, i think freight for both transfers to the states would cost more than the kicker 3 itself. let alone sending it back to oz.
its all poo.
« Reply #5 on: June 02, 2005, 07:13:42 PM »
No they changed it, you only need to send in the track kick x-fer case, you keep the samurai trans fer case.
Offline red_baron
  • 108
  • little red vit
    • surrey zuki society
« Reply #6 on: June 02, 2005, 07:52:05 PM »
i am about to start making my own twin t case set up. using a tracker t box mated to a sammy one.
Offline SiKiD_01
  • 574
« Reply #7 on: June 02, 2005, 07:58:02 PM »
a few people here in oz are doing a dual case set up. only they are doing it in LWB zooks wheres theres heaps of room to keep going back.
i have a swb, and doubt it will be an easy task to get twin transfers under. wild weasel has done this, but extended wheel base and solid axles, what more could you want.
i'm also not too keen on the intermediate shaft, like in a normal sammy set up with a divorced transfer. i would much rather have a kicker set up, where the transfers and gear box are all bolted together solid.
anyway, thanks for the info guys.
Offline hcgalvin
  • 1695
    • Granite Path
« Reply #8 on: June 03, 2005, 04:38:28 AM »
Talk to GRVIT. He lives in Greece and has a SWB. He's going SAS though. But, he did order a Kicker 3 from OTT that's being shipped to greece. OTT was nice enough to find a couple of transfer cases for him in canada and just let him buy them through them. :)
Also, just know that you need to be patient with OTT. It takes a little while to get a Kicker 3. They're a 3 man shop I think, and have loads to do.
« Last Edit: June 03, 2005, 04:40:24 AM by hcgalvin »
Heather Galvin
Offline Natebert
  • 1098
« Reply #9 on: June 03, 2005, 05:27:53 AM »
I don't think that the additional length a kicker3 adds would be an issue in a SWB.
Its marked for Sammy people as a direct bolt on for people who've done a 1.6v conversion.  (stock Sammy t-case location)
