Skip in Kick
  • 1960 Views
Offline RifleRide
  • 29
  • Mentor a Child!
Skip in Kick
« on: June 21, 2004, 09:13:34 AM »
I developed a skip in my 89 kick and it was diagnosed with low compression in #4 cylinder.  Mechanic suggested a valve adjustment might be in order or possible worse problems.  I removed the valve cover and attempted to adjust what seemed to be some over tight valves.  Skip is gone, but not sure I got the right clearance for adjustment.  Heard some rumors that owner manuel not exactly right on their info.  Anyone know the gap for 1.6 intake and exhaust valves?
Offline explosivo
  • 3157
Re: Skip in Kick
« Reply #1 on: June 21, 2004, 09:32:41 AM »
It tells the clearances (hot and cold) on one of the stickers inside the hood, IIRC.
omghi2.us[/url]
Re: Skip in Kick
« Reply #2 on: June 21, 2004, 11:51:22 AM »
.006 intake .008 exhaust (inches)
in mm I don't know, one thing that
caused me problems was that Zuke Valves
tighten as they wear, which creates burned
valves, and a valve job for me at 200,000
until then the motor had never been apart.
Good Luck
Offline chopper
  • 57
  • go where no man goes
Re: Skip in Kick
« Reply #3 on: June 21, 2004, 07:32:55 PM »
wow that is so correct on the burn valves occuring, i jsut rebuilt my topend at 230,000 and now she purrs like a kitten, pretty easy job too.
92'sas tracker 32" muds, oba, locked and loaded, 8274, toys
cardomain page http://www.cardomain.com/ride/553823
Offline RifleRide
  • 29
  • Mentor a Child!
Re: Skip in Kick
« Reply #4 on: June 21, 2004, 11:50:46 PM »
Thanks guys!!!  You just proved, you can't go by the numbers in the chilton's "maybe its like this" book.
