Coil Spring Spacers
  • 27 Replies
  • 7249 Views
Offline kubik1981
  • 232
  • Drive it like You stole it. Then fix it.
Coil Spring Spacers
« on: September 20, 2010, 06:41:44 PM »
I ordered my second set of spacers from Jeff1997 for my newer ride a 96 5sp tracker. On my 91 it took me 5 hours to install all 4. does anyone know a easy way to install these i was going to get a coil spring compressor but it will not work because of the bump stop. and i used strut spring compressor on my old one. any help would be great, i will be doing this, this weekend in my driveway with air tools, a jack and jack stands.
Offline mike5721947
  • 545
Re: Coil Spring Spacers
« Reply #1 on: September 20, 2010, 09:28:30 PM »
you can get coil spring compressors that mount externally one on each side of the spring. i picked mine up from princess auto for 20 bucks.
31" kumhos 3inchs of lift.
Offline kubik1981
  • 232
« Reply #2 on: September 21, 2010, 03:57:58 AM »
I used one of those on my old tracker and I had a hard time because the compressor would hit the control arm
Offline noiseyjack
  • 44
« Reply #3 on: September 21, 2010, 05:04:40 AM »
Offline kubik1981
  • 232
« Reply #4 on: September 21, 2010, 06:40:52 AM »
I guess I am not getting what you are saying
Offline noiseyjack
  • 44
« Reply #5 on: September 21, 2010, 11:34:15 AM »
It's a good guide and easy to follow. That's what I used the first time . I have one 5 since then. and did each one faster.
Offline rascott
  • 669
  • 15
« Reply #6 on: September 21, 2010, 12:59:26 PM »
i used a spring compressor the first time i did this.
i just finished increasing the puck size and did it without a compressor. it was much easier than messing with the compressor.
i found the a-arm would drop enough to just stick 'em in.
« Last Edit: September 22, 2010, 05:26:12 PM by rascott »
Offline noiseyjack
  • 44
« Reply #7 on: September 21, 2010, 02:22:39 PM »
If you go to the top of this page to the GEAR GUIDE and click on it you will find how to do this and a lot of outher stuff :)
Offline Jluck
  • 1389
  • 40
« Reply #8 on: September 21, 2010, 02:28:26 PM »
unbolt the anti-sway bar in front and the wishbone link in rear (and all shocks) should be a 1/2 hour job per end if you do this.
Offline kubik1981
  • 232
« Reply #9 on: September 21, 2010, 03:08:54 PM »
ok so for the front if i undo the sway bar links it will drop enough. will i have to do anything with the cv shaft. also i prolly should put the jack under the control arm and slowly lower it until the spring goes loose
Offline Jluck
  • 1389
  • 40
« Reply #10 on: September 21, 2010, 04:07:39 PM »
yep, the cv shaft (should) come out pretty easy when the knuckle swings down. and always smart to slowly let it down with a jack.
Offline kubik1981
  • 232
« Reply #11 on: September 21, 2010, 04:10:42 PM »
ok cool when i take the snap ring off of the cv shaft do i take the alen bolts at the knuckle for the hubs
Offline Jluck
  • 1389
  • 40
« Reply #12 on: September 21, 2010, 04:12:51 PM »
if the c-clips off you dont need to remove the whole hub just slide out the cv
Offline kubik1981
  • 232
« Reply #13 on: September 21, 2010, 04:15:30 PM »
as far as i know i think they are on there never had to replace the shaft just the passanger side lockout
Offline kubik1981
  • 232
« Reply #14 on: September 25, 2010, 07:38:13 PM »
well i got her done thursday only took 3 hours doing it myself.
