kicker 2
  • 9 Replies
  • 4441 Views
Offline ridgerat4x4
  • 30
kicker 2
« on: September 20, 2010, 07:38:26 PM »
where can i find out more info about this setup i tried the search didnt help a lot
« Last Edit: September 21, 2010, 06:19:06 PM by ridgerat4x4 »
my crazy junk ,77 M35a2 duece and half,86 dodge long bed on 2.5 tons (under construction), 98 tracker, 91 dodge diesel
Re: kicker 2
« Reply #1 on: September 20, 2010, 09:08:51 PM »
http://www.ottindustries.com/kicker2.htm
Google search kicker3
Enjoy,
Offline Jluck
  • 1389
  • 40
Re: kicker 2
« Reply #2 on: September 20, 2010, 09:48:05 PM »
good luck.... I talked to the new owners a couple months ago and they were talking about dropping the kicker line. the new owners are not off-roaders and said "theres not enough profit" from us off-road degenerates. call them, talk 'em in to keeping them.
Re: kicker 2
« Reply #3 on: September 20, 2010, 10:24:45 PM »
What are they going to sell if they drop the off road degenerate stuff ???
Offline Jluck
  • 1389
  • 40
Re: kicker 2
« Reply #4 on: September 21, 2010, 07:44:51 AM »
they are a hot rod & Harley type shop.(big money type stuff) I cant remember there name right now. they are keeping the OTT web site for now but if you call they will give you there real web address. when I talked too them last they had one kicker4 box with out the shifter riser (only work with auto) and no plans for building more. I hope they have changed there minds!
Offline joesteak
  • 74
Re: kicker 2
« Reply #5 on: October 02, 2010, 10:49:56 AM »
Save yourself some headache and do the RingR.  I wish I did.  There's a ton more aftermarket support for toyota gearing.  My kicker 2 took 9 months to show up.  It sounds already like the new owners will have the same crappy customer support as the old owners (if not worse).  That could seriously F your entire build.
Offline Freak
  • 129
    • Freakreation
Re: kicker 2
« Reply #6 on: October 04, 2010, 07:52:07 AM »
I was going to get the Kicker 3 so I looked into it and it turns out that the new company is only dropping the kicker 1! They will still make 2,3,and4. I also understand that they are turning them out much quicker than before. But they have raised the prices... surprise surprise.
Re: kicker 2
« Reply #7 on: November 08, 2010, 09:35:53 PM »
what was there turn around time on the kicker three setup now, just curious, i was going to order in the middle of there buy out and didn't want to wait so i built my own and works great, guess i should use to my advantage that i run  run a cnc machine every day sure helps when you need stuff built
Offline allout
  • 41
Re: kicker 2
« Reply #8 on: November 10, 2010, 08:23:24 PM »
called OTT the other day. They still are unsure about the kick3. Told me to call them at the end of Nov. New price is $1200 and did not want a core. I may just go with the undertaker.
94 Tracker, SAS with YJ's, spartan locker front , welded rear, 33/10.50's, 4.24tcase gears, Warn M8000. Toy axles being built up.
Re: kicker 2
« Reply #9 on: November 11, 2010, 06:39:23 PM »
 i just got all my machine work done to build my own i building two others thinking i will have mine in this weekend in the new sami project i wanting to take it out the 19 or  20 and do some wheeling   i built enough parts to build the two other and welded up another case and machine the out put shaft on trans so i can sell them if some one might be interested
