My first Sami ??????
  • 9 Replies
  • 3604 Views
Offline c3006
  • 263
  • 10
« on: October 01, 2010, 09:00:08 AM »
I just brought my first Sami,its a 92 with a 1.3 FI. The temp gauge and speedo do not work and I thought I would Pull the cluster as I only seen 2 phillips screws under it and hope that might release it and let me take a peep but alas that was not to be so. Anyone have the secret to getting the cluster out before I bust something.  Thanks  c
« Last Edit: October 01, 2010, 03:37:42 PM by c3006 »
Offline jow003
  • 403
Re: My first Sami ??????
« Reply #1 on: October 03, 2010, 03:09:46 PM »
speedo is a cable that goes straight from the cluster to the t-case (atleast in mine), thats an easy fix you can reach behind the cluster and pull old on out and stickin the new one in.
-O
BUY MY STUFF!! pm for details
87 Samurai...
5" SPOA/OTT -RRO
1.5" leaf springs-OME
RUF conversion-Trail Tough
1" shackles
33x1250x15 MTZs
15x8- DC-2s
Offline airmanwilliams
  • 913
« Reply #2 on: October 03, 2010, 09:55:28 PM »
there are two bolts holding up the steering column just take those out and lower the column abit and then take an allen wrench and take out the small bolt holding the instrument cluster cover and take the cover off and then it should come out.
1993 4door Suzuki Sidekick JX
Offline c3006
  • 263
  • 10
« Reply #3 on: October 05, 2010, 03:18:10 AM »
I tried and could not get my hand up behind it for all the stuff back there,I will try lowering the column this morning. thanks  c
Offline c3006
  • 263
  • 10
« Reply #4 on: November 25, 2010, 04:14:20 PM »
Follow up on this is there are 2 screws under the cluster but there are 2 above it on top of the dash that are flush mounted and hard to see,after droping the column and takeing out all 4 screws it popped right out.  thanks  c
Offline dwebb11b
  • 37
  • If your gonna be original expect to be copied
« Reply #5 on: December 01, 2010, 07:04:31 PM »
i am in the same boat.sorta.i just bought an 88jx and know jack about it.but i do know what i want to do with it.small lift crawler bumpers,carb,headers,and new interior.i got it for 700 and its got a bit of rot in the usual places.also what is a locked rear end?
Offline dwebb11b
  • 37
« Reply #6 on: December 01, 2010, 07:06:01 PM »
also you got a good looking sammie there.
Offline c3006
  • 263
  • 10
« Reply #7 on: December 02, 2010, 04:08:32 AM »
Thanks,Im havin alot of fun with mine but dont plan on off road. I guess from what I have read about lockers it gives you the ability to make both rear tires turn together for traction.  Good luck with your project.  c
Offline my996duc1
  • 222
« Reply #8 on: December 02, 2010, 08:07:33 AM »
1987 Tintop / 1.6 16V ps & ac / 6.4 t-case Twisted TT / 4.30 R&P Hybrid rear / Double Tough axles / Shrockworks all around / ARB f&r / Mighty Kong & TT full skid / DS disconnect / CV shafts f & r / YJ missing links f & r / Petroworks tintop cage / 15 gal Tank / 31" x 12.50 Pro Comps
« Reply #9 on: December 02, 2010, 05:49:56 PM »
There is also a good forum post about lockers over at http://www.zukiworld.com/forum/technical-discussion-beginner-repair/merged-'lockers-the-best-but-most-'-and-'mini-spool-vs-locker-'/ including the different types and some of the positives and negatives of the different types.
