G13a fuel consumption problem
  • 2523 Views
Offline jEm
« on: October 05, 2010, 07:51:00 PM »
Hi Guys,
I just did a major service on my SJ413, timing belt, crank seals, cam seals, oil change, plugs etc.
Car is running like a dream, only problem is that she now consumes so much more fuel than prior to the service.
I use to get 300kms per tank, now it's significantly dropped to under 200kms per tank. Any ideas as to what the problem could be? Have I accidentally adjusted something I shouldn't have??
Please help.
Re: G13a fuel consumption problem
« Reply #1 on: October 06, 2010, 03:03:33 PM »
The only thing I can think of is if your carburetor now needs a bit of a tune-up.  You shouldn't see a 30% drop in mileage over a tune-up.
Have you double checked your timing?
Offline jEm
« Reply #2 on: October 10, 2010, 05:14:37 PM »
Mate, thanks for reply.
I'm hoping the carby is ok, she is ideling a little higher than usual, might shine the timing light on her and check it out.
Are there any key signs of timing being slightly off?
« Reply #3 on: October 10, 2010, 11:30:56 PM »
Idle being off, usually you will notice the power being at a different spot then before, or a dead zone in your throttle.  You might try running higher grade gas, if your idle is to far advanced it will run much better with premium fuel.
« Reply #4 on: October 11, 2010, 07:26:18 AM »
Did you gap the spark plugs before fitting them?
Offline tipover
  • 422
« Reply #5 on: November 09, 2010, 04:46:10 PM »
I think you should put a timing light on it.  that will also tell you it the timing belt is off a tooth.  interesting problem.  keep us posted.
RV Dingy-2003 2 door tracker
RV- 31' Monaco Mckenzie
