Trackick on 37! (pics)
  • 47 Replies
  • 10578 Views
Offline 1bigtracker
  • 3409
Re: Trackick on 37! (pics)
« Reply #15 on: May 12, 2004, 02:30:51 PM »
yea i saw that
Offline 92Sidekick4x4
  • 1456
« Reply #16 on: May 12, 2004, 03:48:46 PM »
i seen that hood scoop today at no limit auto, (custom shop here in town) i shoudl seen the price, there cool, heh i think anyways.
Offline tracker8wr
  • 568
  • THE BIGGER THE BETTER
    • my home page
« Reply #17 on: May 12, 2004, 04:05:33 PM »
hey can u post some more pics of the suspinsion. if possible some measurements and possibly some geometry angles. if the pics r to big u can send them to tracker8wr2003|removethispart|@yahoo.com. any info u can provide would be very helpfull. i want to run 35" to 36" swampers.
4 1/2 body
Coil spacers
cheap but effective
31" LTB Swampers
Offline jagular7
  • 1026
  • Jagular7
« Reply #18 on: May 12, 2004, 04:20:27 PM »
Your friend's Trackick looks great and the color clashing between the 2 in the pics is fantastic!!!
Notice his mirrors and door handles are painted to match, hummmm. Even the shadow flames.....
Anyways, from the pics, it looks like the body is lifted off the frame pretty good, that there is a custom front subframe which the Calmini arms bolt to, same on the custom 9" mount and running the 6.50's (real cool), then the rather large coil spacer on top of front coil, that there is a trailer plug above the rear axle, hard to tell if there is a slip in the rear ds, then steps on the faces of the bumpers.
Lenexa, KS
Offline explosivo
  • 3157
« Reply #19 on: May 12, 2004, 04:45:01 PM »
Since it's kinda related to this topic, I thought I'd ask ya a quick question, Mike: Do those Ford 9" rearends out of older Broncos have the same kind of flange that the stock tracker rear axle does? When you put your 9" rearend in, did you have to have a custom driveshaft made?
omghi2.us[/url]
« Reply #20 on: May 12, 2004, 10:32:40 PM »
It looks great 8) Good to see he got it done ;) Has he tried it out much to see how the Toy shafts will hold up to the 37's?
LAter,
Offline Natebert
  • 1098
« Reply #21 on: May 13, 2004, 02:46:52 AM »
I like the strut brackets.
Always wondered how'd one could keep it align-able.
TITAN
« Reply #22 on: May 13, 2004, 09:31:48 AM »
it almost makes me sad that i'm only rolling on 34s.  its a bad bad day in VT. :'(  you have any more info on the front 9in?
stu
wat setup/suspension r u running ?? cuz the highes buyable i can think of is  6 clamini combo and 1.5 inch coil spacers with tirmming
Offline 1bigtracker
  • 3409
« Reply #23 on: May 13, 2004, 10:04:24 AM »
3 in body lift
TITAN
« Reply #24 on: May 13, 2004, 10:24:34 AM »
THATS IT????!!!! i thought u could only run like 30's!!!
dude get a 1.5 coil soacers and get like 35's!! or the vitar soring lift thing and run 37's!!
Offline 1bigtracker
  • 3409
« Reply #25 on: May 13, 2004, 10:38:39 AM »
well i have modded the sheat meatl as far as you can without building new body panels.  and after a year of hard running the front springs are sagging bad so i did build some 1 1/2 coil spacers for the front.  i would like to get the front end bullet proof before going any bigger.  when its all said and done i would like to be running 35in boggers.
stu
TITAN
« Reply #26 on: May 13, 2004, 11:31:27 AM »
cool cool :)
Offline Mikerpm4x4
  • 2875
  • Redline... all the time!
    • www.rpm4x4.com
« Reply #27 on: May 13, 2004, 12:20:58 PM »
Those are the only photos I have. Its not my rig. He lives about an hour away so I dont see him as often as I would like to. The front of the frame is completely custom.   No stock control arm or diff brackets were used. This would be very difficult to explain.
To run 35s or 36s you will need to know how to do some pretty wild fabbing or some extensive trimming. 33s are a lot easier to run... not to mention all the axle components that would need to be upgraded to hold up.
TITAN
« Reply #28 on: May 13, 2004, 12:44:04 PM »
wat r u running? (i thought 35's)
Offline Mikerpm4x4
  • 2875
    • www.rpm4x4.com
« Reply #29 on: May 13, 2004, 12:49:34 PM »
I am! I also have a lot of weird tweaks to make them fit.
Mike
