Trackick on 37! (pics)
  • 47 Replies
  • 10575 Views
Offline Mikerpm4x4
  • 2875
  • Redline... all the time!
    • www.rpm4x4.com
« on: May 12, 2004, 11:57:12 AM »
Offline Mikerpm4x4
  • 2875
    • www.rpm4x4.com
Re: Trackick on 37! (pics)
« Reply #1 on: May 12, 2004, 11:58:04 AM »
Offline Mikerpm4x4
  • 2875
    • www.rpm4x4.com
« Reply #2 on: May 12, 2004, 11:58:48 AM »
TITAN
« Reply #3 on: May 12, 2004, 12:00:14 PM »
ITS HUGE!!!  ;D ;D ;D first personne on 38's wins a mystery prize!!!!  :P :P :D :D
Offline Mikerpm4x4
  • 2875
    • www.rpm4x4.com
« Reply #4 on: May 12, 2004, 12:33:24 PM »
ENGINE
Type: 16 valve 1.6 liter stock
Aspiration: 2 inch cat back (not finished)
DRIVETRAIN
Transmission: 5 speed
Transfer Case: 4.23 to 1 Calmini Rockcrawler
SUSPENSION
Front: Calmini 3 inch widened 2 inches and modified to 5 inches of lift
Rear: Calmini 3 inch modified to 5 inch lift - long rear arms                                       Shocks: Rear:  11 inch travel Rancho / Front Old Man Emu
AXLES/DIFFERENTIALS
Front:Center mount Ford nine inch with Detroit locker
Toyota PU cv shafts.
Rear: Ford 9 inch ? spool - 31 spline
Ring-and-Pinion: 6.50 to 1
WHEELS AND TIRES
Wheels: 15x10 American Racing Chrome
Tires: 37-12.50-15 Goodyear MTRs
OTHER MODS
There are many. here is a short list of mods
Homemade front and rear bumpers with line X coating
Toyota 4x4 Van knuckles with dual piston calipers
Calmini idler brace
Rear: disc rotors from front Tracker / calipers from rear Saturn / working parking brake
Roll Cage
Rocker skids connecting to a Full Belly Pan (still being built)
4" gas tank lift
Offline 1bigtracker
  • 3409
« Reply #5 on: May 12, 2004, 12:38:04 PM »
it almost makes me sad that i'm only rolling on 34s.  its a bad bad day in VT. :'(  you have any more info on the front 9in?
stu
Offline Mikerpm4x4
  • 2875
    • www.rpm4x4.com
« Reply #6 on: May 12, 2004, 12:43:52 PM »
stu
Its a totally custom one off unit. Lots a machining ... and thought, went into it. Not something that would be very easy to do much less explain.
Mike
  • 6603
  • 69
« Reply #7 on: May 12, 2004, 12:45:26 PM »
ENGINE
DRIVETRAIN
SUSPENSION
AXLES/DIFFERENTIALS
WHEELS AND TIRES
OTHER MODS
Calmini idler brace
Roll Cage
4" gas tank lift
Hey Mike,
Looks nice. Is the upper 3-link on the rear stock Calmini?
Offline explosivo
  • 3157
« Reply #8 on: May 12, 2004, 01:37:40 PM »
That's kinda what I was contemplating doing... modifying the Calmini lift from 3" to around 7-8" so I could remove my body lift... Looks like this guy knows what he's doing though, as I'll never do that. Plus, the 9" diffs must rock! :o
edit: It also doesn't look like it's sitting much higher than your rig, Mike...
« Last Edit: May 12, 2004, 01:42:01 PM by explosivo »
omghi2.us[/url]
Offline Rod
« Reply #9 on: May 12, 2004, 01:39:27 PM »
The Trackick looks GREAT!
Do you have any pics of the belly pan/rocker sliders?I would like to add a belly pan a rocker sliders...I'm looking for ideas.
Did you drop the front diff to add more lift to the IFS?
Rod
Rod
Offline Mikerpm4x4
  • 2875
    • www.rpm4x4.com
« Reply #10 on: May 12, 2004, 01:42:50 PM »
Hey Mike,
No he made a longer one and painted it to match the kit.
Offline Mikerpm4x4
  • 2875
    • www.rpm4x4.com
« Reply #11 on: May 12, 2004, 01:49:47 PM »
7 or 8 inches!  :o That would take some serios fab work. His rig does sit around 2 inches higher than mine. Our suspension is very similar. most of the height difference is in the tires.
Offline Mikerpm4x4
  • 2875
    • www.rpm4x4.com
« Reply #12 on: May 12, 2004, 01:54:30 PM »
Rod
This isnt my rig. Its a friend's. I probabally have a pic of my bellypan around here somewhere. As for the diff drop/ added suspension lift its pretty much all built from scratch.
Mike
Offline explosivo
  • 3157
« Reply #13 on: May 12, 2004, 02:02:34 PM »
Which is why I decided against it.
Originally I was thinking that it would be fairly simple and straightforward, then I started studying the front suspension stuffs, and realized that as soon as I started, I'd be way in over my head.
Which is why that guy's rig is so cool... but I imagine that he still has rubbing problems even with cut fenders/moved floorboards?
omghi2.us[/url]
Offline NY_SIDEKICKER
  • 2274
  • YOU WANNA RACE THE ZUKE !
    • OBSESSIVE BEHAVIOR !
« Reply #14 on: May 12, 2004, 02:05:23 PM »
SWEET LOOKING TRACKER......HE NEEDS A ZUKIWORLD WINDSHIELD DECAL.......STU,      HE'S GOT YOUR HOOD SCOOP  ;D........ MATTY  8)
