lock-right install?
  • 2068 Views
Offline tracker8wr
  • 568
  • THE BIGGER THE BETTER
    • my home page
lock-right install?
« on: June 17, 2004, 03:26:12 PM »
i put it in my 94 tracker standard and the passenger  wheel does not lock in it jut grinds on the gears. what the hell is going on and also i had 2 washers on either side not one. should i put them both in or just one like instructions say. we put my friends to gether with no problem.
4 1/2 body
Coil spacers
cheap but effective
31" LTB Swampers
Offline Kreg
  • 795
    • Island 4x4
Re: lock-right install?
« Reply #1 on: June 17, 2004, 05:45:51 PM »
Not sure about the thrust washers. My truck only had one on each side.
Are you running the Lockrite that uses the stock side gears?
Perhaps your passenger side gear is worn out and isn’t meshing properly with the coupler.  ???
Offline tracker8wr
  • 568
    • my home page
« Reply #2 on: June 17, 2004, 07:16:28 PM »
i checked the gearts like it said on the install booklet. it looked to be in good condition. i am running the stock gears. i don't think that is the problem. i am going to have to wait till next week to pull it part so until then i will be trying to get some ideas. i just bought a house so it is rquiring ALL of my time right now. any more suggestions.
4 1/2 body
Coil spacers
cheap but effective
31" LTB Swampers
Offline xamtex
  • 72
« Reply #3 on: June 18, 2004, 11:33:22 AM »
if you had 2 thrusts in each side then you need 2 thusts each side!the lockright utilises your origional couplers and thrusts,if it needed 2 thrusts as standard then you need 2 thusts with the locker. ;)
god must love crazy people,he made so many of them!!!
