Driver side window switch not working
  • 1853 Views
Offline nuts4hotwheels
  • 169
  • Black Sunshine
« on: October 09, 2010, 06:05:00 AM »
I have a 1998 4-door Tracker and my driver side window switch quit working.  It rolls down the passenger side and the door lock button works but it will not roll down the driver window.  It originally got stuck in the down position and I hooked the motor to a battery to roll it up, so I know the motor is good.
Is there a common problem with a ground or something?  I am thinking about wiring it with a aftermarket toggle switch to get it to work.
Any suggestions? ???
Black Sunshine
1998 4 dr Chevy Tracker 4x2 1.6L-16V
-K&N Performance Air Filter
-Thrush Glasspack -235/75-15 Pathfinder Trail A/P Tires  -Sony Xplod Cd Player -400W Visonik amplifier -2 10" Visonik Subwoofers *******************************
Offline jeff1997
  • 1228
  • 27
Re: Driver side window switch not working
« Reply #1 on: October 09, 2010, 06:15:30 AM »
I had the same problem on my 97. The driver's switch is worn out. The others will work but the driver's gets the most use and thus the contacts wear out or like mine break. I got a new switch assembly off ebay for like $15. It is just a plug and play fix then. Try the junk yards also.
3" Masterkit1 body lift
Custom strut spacers
  • 169
  • Black Sunshine
« Reply #2 on: October 10, 2010, 05:24:01 AM »
I looked on ebay and they are wanting $80-$100 for a switch.  I will keep a look out on ebay and will try to get a cheap one.
Black Sunshine
