unknown sensor question
  • 1550 Views
Offline airmanwilliams
  • 913
« on: October 11, 2010, 12:37:17 PM »
Ok so I just sprayed off my transmission alittle and found a sensor that isnt connected to anything. Can anyone tell me what it is and if its important?
1993 4door Suzuki Sidekick JX
Offline ack
  • 1659
  • Professional askhole
    • Ack's FAQ
Re: unknown sensor question
« Reply #1 on: October 11, 2010, 01:58:26 PM »
I believe that is the fifth gear switch.  It works with the ECU to adjust ignition/fuel delivery for optimum mileage.
otherwise it is the transmission's reverse gear switch - which turns on the backup lights in reverse gear.
Ack
  • 913
« Reply #2 on: October 11, 2010, 02:04:56 PM »
thanks for the help my reverse lights dont work so that may be it. I have two wire from a connector on the harness that arent connected to anything and i thought it just went to the lights so thank you for the info I will connect the wires to that then.
