EFI and Carb use the same head??
  • 1936 Views
Offline c3006
  • 263
  • 10
« on: October 13, 2010, 02:53:09 PM »
I have a 92 Sami with a 1.3 with EFI. I brought a 1.3 out of a 87 with a carb. I want to swap the long block off the carb motor into my sami but use my EFI instead of the carb. Am I gonna run into a passel of trouble with this or should it just be a direct swap?   Thanks  c
Re: EFI and Carb use the same head??
« Reply #1 on: October 13, 2010, 05:32:52 PM »
It will work fine.  The only 2 differences between carbed and EFI heads....the EFI cam doesn't have a lobe for the fuel pump and the EFI has a block off plate over the fuel pump hole (it can be removed, so the fuel pump can be put on).
Offline c3006
  • 263
  • 10
« Reply #2 on: October 13, 2010, 06:20:16 PM »
Thank You  ;)   thats what I needed to know
