Technical Discussion - Beginner / Repair
Body Lift
Body Lift
samuride1
42
Body Lift
October 19, 2010, 02:20:44 PM »
What would i need to do a body lift the right way? I have found several kits. Will I need new body bushings, longer shocks, etc.?
I know I will probably have to extend the shifters!
1988 Suzuki Samurai
doughboy0379
290
9
Blinker fluid is free so use it........
Re: Body Lift
October 21, 2010, 10:30:18 PM »
I am pretty sure the shocks are not mounted anywhere to the body (I don't feel like double checking that right this minute sorry) how tall are you wanting to go? as far as I know if you get a kit then everything you need will be in it (never done one so could be wrong) as long as you don't go over 2-3 inches then I think your shifters would be ok they would just not stick up as high into the cab so then it would be a matter of can you still reach them comfortably from the drivers seat.
86 Samurai, SPOA, 3" HD leaf springs, 31/10.5/15 Big-O XT Tires, K&N Air Filter, Doug Thorey Header, more coming when I find the funds
Drone637
8121
116
Evil Cow
Re: Body Lift
October 21, 2010, 11:57:50 PM »
You can go up to 2" before you need to start modifying things. I'm not a big fan of body lifts myself, I think the 2.5" OME springs or a SPOA lift are a better fit for Sammy.
