2wd/4wd auto transmission interchangable?
  • 2542 Views
« on: June 13, 2004, 04:22:23 AM »
  Can I use a '94 2wd Tracker auto transmission in my '92 Sidekick 4wd auto?
Offline Agent Orange
  • 711
    • Trying to learn
Re: 2wd/4wd auto transmission interchangable?
« Reply #1 on: June 13, 2004, 04:45:23 AM »
no, it has to come from a 4x4 rig. the two are very different.
Offline idaholwb
  • 772
« Reply #2 on: June 13, 2004, 02:29:49 PM »
 If you get the trans from a 4 door, the trans has a dummy t-case on it. The 2 doors don't use a dummy, with the only exception being an x-90. They have the same trans that the 4 doors and late model 2 doors have.
« Last Edit: June 13, 2004, 02:30:52 PM by idaholwb »
97 Sport
265/70-16s
2" lift
2.0 swap
« Reply #3 on: June 13, 2004, 06:26:52 PM »
A true dummy, or  a T-case shell that could be machined
and put into service ??
Offline idaholwb
  • 772
« Reply #4 on: June 15, 2004, 04:56:55 PM »
 It's just a dummy, Dummy!
;) ;D
97 Sport
265/70-16s
2" lift
2.0 swap
Offline jagular7
  • 1026
  • Jagular7
« Reply #5 on: June 16, 2004, 02:54:04 AM »
If it's a dummy, does it have more fluid capacity since it's empty?
Lenexa, KS
« Reply #6 on: June 16, 2004, 12:16:27 PM »
Sure, use it for an extra fuel tank   ;)
Offline idaholwb
  • 772
« Reply #7 on: June 16, 2004, 05:08:54 PM »
 Not sure about the fluid capacity. I do know that it is a kick case only without the front output hole bored and no shifter.
97 Sport
265/70-16s
2" lift
2.0 swap
