1.3 0r 1.6L in Samurai?
  • 3721 Views
« on: October 25, 2010, 09:06:22 AM »
I'm looking at a Samurai 1988, owner is not sure if the motor is a 1.3 or 1.6L is there a way to tell which motor is in it? I have attached a picture not sure if this will help or not?
Thanks
« Last Edit: October 25, 2010, 09:57:52 AM by alpineman »
Re: 1.3 0r 1.6L in Samurai?
« Reply #1 on: October 25, 2010, 10:12:39 AM »
Take a look at the block on the (US) driver's side, near the bellhousing it will say G13 or G16.
« Reply #2 on: October 25, 2010, 03:10:16 PM »
I know it's not a 1.6l 16v.  Unfortunently I think the 1.6L 8v and the 1.3L have a similar looking valve cover.
« Reply #3 on: October 25, 2010, 09:49:24 PM »
Yep, that is the most positive way to tell.  Since it could be a 1.6 with a 1.3 intake and carb setup on it.
The 1.3 will say either 1298 or 1324 back by the bellhousing.
The 1.6 will say 1590 back by the bellhousing.
Offline fordguy79
  • 494
  • 8
  • long beach Wa,
« Reply #4 on: October 26, 2010, 08:30:28 PM »
stock 5 speed would need adapter plate to 1.6 ???
« Reply #5 on: October 27, 2010, 08:58:33 AM »
Not if the block has been drilled and tapped.
« Reply #6 on: October 27, 2010, 09:06:09 AM »
You can do that? Why doesn't someone make 1.6 blocks for Samurai install
that don't need a plate instead, sounds like a better idea to me
« Reply #7 on: October 28, 2010, 10:07:42 AM »
Probably because it is cheaper and easier to make the adapter plate.
