tie rod ends
  • 1574 Views
Offline smife
  • 179
tie rod ends
« on: October 25, 2010, 01:41:09 PM »
Has anybody that has done the "widening mod" replaced a tie rod end? If so where did you find it?
All the tie rod ends I can find are 90mm and the factory end is about 110mm
Everything I see says to replace the innner and outer together on 94 and up. Does that mean the inner replacement is longer?
With the 90mm the outer tie rod ends it only screws on 2 threads......
Re: tie rod ends
« Reply #1 on: October 26, 2010, 04:14:55 AM »
Is one side threaded in farther than the other? I replaced my tie rod ends after I did the widening and had no issues with length. Got mine from Vato Zone.
