Yay! Fixed 4WD
  • 1608 Views
Offline explosivo
  • 3157
Yay! Fixed 4WD
« on: June 15, 2004, 04:44:36 PM »
And I didn't have to spend several hundred dollars on steel housings! I just put a strap:
over the snout of the third member, and bolted it to the crossmember, which effectively fixed my broken pinion mount. It's only temporary, but it'll do until I get the proper funds to put a GV housing in.
After I put the strap on, I took a little test drive through the trails behind my house, and not thinking about the snorkel, ignored some overhanging trees. This was the result:
I'm still happy, since I fixed a nagging problem and the damage of my brief trip was minimal. I'll be sure to be a bit more observant when out on tight trails ;D
omghi2.us[/url]
Offline 1bigtracker
  • 3409
Re: Yay! Fixed 4WD
« Reply #1 on: June 16, 2004, 04:39:00 AM »
i have seen at part stores(ricer shops) they have a cone filter gaurd.  it goes about have the way around the filter. it might be right up you alley(sp). even though it is crome.
stu
Offline explosivo
  • 3157
Re: Yay! Fixed 4WD
« Reply #2 on: June 16, 2004, 11:11:21 AM »
I've already got an idea for a guard in my head... just gotta make time (IE get unlazy) to make it. ;)
omghi2.us[/url]
