1 gen body lift on a 2000 tracker?
  • 2063 Views
Offline Hellfire
« on: October 26, 2010, 02:46:31 PM »
Hello, I bought a Rocky Road 2'' body lift for my 2000 tracker and they sent me one for the first gen models. I called and talked to them and they mailed me the brake line extensions and said body lift's are the same. What do you guys with experience working on both models think,are they the same?
Offline MUD CHILD
  • 355
  • 9
Re: 1 gen body lift on a 2000 tracker?
« Reply #1 on: October 26, 2010, 03:26:21 PM »
Yes the body lifts are the same, but you will need a steering shat extension of the steering shaft or it will bind. Here is a link to my site I make the steering shaft extensions.
 http://www.srcustoms.ca/index.php/products
NO DITCH TO DEEP NO HILL TO STEEP
http://srcustoms.ca/
Offline Trackerprts
  • 106
  • Aiirbag
« Reply #2 on: October 26, 2010, 07:10:49 PM »
They get them from Sky Offroad Design. They are the same. You will probably need to get longer bolts for the front mount and good luck figuring out where the break lines go Rocky Road does not even know.
You will need to fab some mounts for your rear break lines.
99 Tracker pieced together out of 3 cars.             RR Body and suspension lift ,31 10.5r15
winch bumper,rock sliders
Offline MUD CHILD
  • 355
  • 9
« Reply #3 on: October 26, 2010, 07:31:08 PM »
Actually we MAKE everything we sell, our steering shaft spacer are NOT from sky. Ours are machined from 1 solid piece there are two pieces of tube, one inside the other. We also supply the correct hardware for the kit unlike theres, and ours are are $10 cheaper and they actually work, so to sum it up they are NOT the same at all.
Offline bzzr2
  • 1011
« Reply #4 on: October 28, 2010, 07:54:56 AM »
you will need longer front bolts, my rr bl did and they sent all the 'right' parts...  the brake line extensions are not needed and nothing more than a waste of money.  some tiewraps on the front strut if needed, no they never broke or came off and i beat the snot outta mine.  for the rear simply disconnect the parking brake clip, this frees things up nicely.
09 taco reg cab short box 4x4
Offline Hellfire
« Reply #5 on: October 28, 2010, 04:57:05 PM »
Awesome, fellas! Thanks for all the help. Anyone have an install write-up?
