Sami t-case in sidekick?
  • 3444 Views
Offline brenzuk
  • 43
« on: October 28, 2010, 12:40:42 PM »
Will adding a samurai t-case behind my sidekick t-case give me any final drive reduction with both cases in high range or would I need gears in the sami case.
Re: Sami t-case in sidekick?
« Reply #1 on: October 28, 2010, 01:06:06 PM »
You will get a high range reduction, one of the advantages of the Samurai t-case conversion:
High - 1.409
Low - 2.268
Offline whitfield
  • 633
  • 4-dr Kick on 34's
« Reply #2 on: October 28, 2010, 04:14:41 PM »
and not just .4 reduction....   It is .4 x your diff gearing.
5.125:1 = 7.175
4.62:1   = 6.468
4.30:1   = 6.02
« Last Edit: October 28, 2010, 05:07:13 PM by whitfield »
Offline whitfield
  • 633
  • 4-dr Kick on 34's
« Reply #3 on: October 28, 2010, 04:42:21 PM »
And With Myron's Pink Snatch
And with Trail Gear's Toyota based IFS width / Off set diff / Rock Assult rear housing
T-case mounting and drive line angle should not be an issue.
Should even leave some loose change for custom 3-link brackets and drive shafts.
« Last Edit: October 28, 2010, 04:46:55 PM by whitfield »
Offline utahskibum
  • 76
« Reply #4 on: October 28, 2010, 08:59:37 PM »
Pink Snatch? Is that just a cradle for the sami case if put after the kick case? Where is that sold?
Offline brenzuk
  • 43
« Reply #5 on: October 29, 2010, 09:56:05 AM »
Great info guys.  Maybe 33's and a five speed are doable after all.  My 31's have killed my highway power.
Offline whitfield
  • 633
  • 4-dr Kick on 34's
« Reply #6 on: October 29, 2010, 06:33:51 PM »
Yes that is ZOR's sammy case cradle.  It is as much a case saver as a mount.  It reinforces the stress points that cause a broken case.  With Myron's poly mounts it shoul dnot be to bad to fabricate it in place under a kick.
I posted on Myrons forum asking about brackets to swap it under a kick...  That would be the hot snatch and make kick guys SMILE>
Offline brenzuk
  • 43
« Reply #7 on: November 01, 2010, 06:52:58 AM »
I have a 4-door, will my driveshaft angles be off without an offset rear housing?  If I do this it will have to be on the cheap.
