swapping leaf springs
  • 2614 Views
Offline ColtonP
  • 147
« on: October 28, 2010, 05:46:17 PM »
I have access to a 1984 toyota pick up. Would I gain any articulation by swapping the toyota leafs into my 1988 sami???
1987 Suzuki samurai BONE STOCK
(SOLD)1990 Samurai 1.6 8v swap, Arb front air locker, spool rear, RRO coil suspension, Chromoly front axles, 33x13.5-15 Swampers, ARB Bumpers, Slider, fender flares, 6.5:1 transfer case, True beadlocks, 1.5" wheel spacers,Roll cage. All in all a lil over 10k in parts uuuggghhhh!!!!!(SOLD)
(SOLD) 2000 Chevy tracker, 4 door, 4x4, auto trans, 2 inch lift,265/70r16 (SOLD)
(TOTALED)1995 tracker lsi, tintop, 3speed auto trans, 2 inch lift, 2 1/2 inch exhaust, 30x 9.5 bfg a/ts, custom front bumper.(TOTALED)
Re: swapping leaf springs
« Reply #1 on: October 29, 2010, 12:41:49 AM »
A bit, but you will need to pull some leafs out and build new spring and pad mounts all round.  I might be easier to go with an RUF (Rear Springs Up Front) and CJ springs in the rear.
Offline S.Sidekick
  • 378
  • Suzi Suzuki
« Reply #2 on: October 29, 2010, 10:21:37 AM »
why would you have to pull leafs out??? I have 84 fronts that I used with my Sidekick SAS swap, and they are already almost negative arche sitting static, so wouldnt this just make them negative?? I know this question was directed towards a sami, but just wondering.
« Reply #3 on: October 30, 2010, 12:42:09 AM »
The springs are likely to be a bit stiff.  The curb weight on an 84 Toyota is around 2800 lbs compared to 1800 for the Sammy.
Offline S.Sidekick
  • 378
  • Suzi Suzuki
« Reply #4 on: October 30, 2010, 08:40:00 PM »
ok, so for a sidekick they will be ok??
« Reply #5 on: October 31, 2010, 11:07:32 PM »
Any spring will work in any vehicle, if it is to stiff you will simply get a really rough ride.
Offline S.Sidekick
  • 378
  • Suzi Suzuki
« Reply #6 on: November 01, 2010, 08:18:09 AM »
thought so, I am planning on repacking the front springs with one of the leafs from the rear once i buy those old man emu 2" lift springs. I heard those flex really well, and then my rig will sit even.
