track/kick has minnor sputering, missing problems
  • 2305 Views
Offline jawman
  • 406
  • 1234
« on: October 30, 2010, 08:15:36 PM »
I have a 95 sidekick 16 valve that I just put a new head gasket in. It runs okay, but it seems to be a little powerless I think it has low compression. when the rpm is about 1000-2500 it seems to sputter a little, but under heavy acceleration and high rpm's I don't notice it. could this be trimming or TPS problems? also I think the kick down cable for the auto trans. needs to be adjusted because it shifts a little hard sometimes and doesn't down shift very fast. How is the cable supposed to be adjusted?
87 Sami tin top
91 4 door SOLD
93 4 door
95 4 door
95 Geo 2dr V6
keep them coming
Offline Hustler
  • 50
Re: track/kick has minnor sputering, missing problems
« Reply #1 on: October 31, 2010, 04:41:15 AM »
id did u check ignition timing and valve adjustment
Offline jawman
  • 406
  • 1234
« Reply #2 on: October 31, 2010, 06:45:49 PM »
I adjusted the valves when I first put it together, so I don't think that is an issue. I do think I might have the dissy off a couple of degrees. Does anyone know what two wires I need to conent on the computer plug buy the battery to time the dissy? the other thing is the stupid timing belt cover is rubbing on the timing belt, so I need to figure out some why to stop that before it rips out the belt. On almost ever 1.6 motor I have seen there has been some sort of interferance in that area.
87 Sami tin top
91 4 door SOLD
93 4 door
95 4 door
95 Geo 2dr V6
keep them coming
« Reply #3 on: October 31, 2010, 11:10:56 PM »
Try advancing the timing a couple degrees above factory spec.  I had a real hole in my power band around 2k until I did that.
Offline jawman
  • 406
  • 1234
« Reply #4 on: November 02, 2010, 09:53:24 AM »
I will try that. would about the timing cover? should a find a new one and mayber that will fix it or what ???
87 Sami tin top
91 4 door SOLD
93 4 door
95 4 door
95 Geo 2dr V6
keep them coming
Offline ranger88den
  • 279
« Reply #5 on: November 02, 2010, 10:30:55 AM »
