I wrote a budget 4 door lift article..
  • 62 Replies
  • 14905 Views
Offline hcgalvin
  • 1695
    • Granite Path
« on: June 09, 2004, 06:17:08 AM »
Hey all... I'm in the middle of an article for a budget 4 Door lift on my site... check it out and tell me what you think so far!
http://www.whitepineclub.com/offroad/tech/budgetbodylift/index.htm
Thanks guys..
Heather
EDIT: I think I am done! Check it out!
« Last Edit: June 09, 2004, 08:22:12 AM by hcgalvin »
Heather Galvin
Offline Cwkick
  • 888
Re: I'm writing a budget 4 door lift article..
« Reply #1 on: June 09, 2004, 06:50:41 AM »
Very clear so far.  Great!
I think your average dumby could probably figure it out.
The drawings and pics. are very good and helpful.
Cwkick
Offline 1bigtracker
  • 3409
« Reply #2 on: June 09, 2004, 08:09:50 AM »
its nice but why won't it work on a 2 door?
stu
Offline hcgalvin
  • 1695
    • Granite Path
« Reply #3 on: June 09, 2004, 08:17:23 AM »
I dunno... it prolly will...  ::)
I just seem to only work on 4 doors  ???  :P  ;D
Heather
« Last Edit: June 09, 2004, 08:17:38 AM by hcgalvin »
Heather Galvin
Offline 1bigtracker
  • 3409
« Reply #4 on: June 09, 2004, 08:18:46 AM »
what about steering?
stu
Offline hcgalvin
  • 1695
    • Granite Path
« Reply #5 on: June 09, 2004, 08:20:24 AM »
stu
I didn't have to do anything with the steering on this truck (it's not power steering), and I didn't have to do anything with the steering on my truck (it IS power steering) either...  :o
so..
hum..
WHAT has to be done to the steering?   ???
Heather
« Last Edit: June 09, 2004, 08:20:59 AM by hcgalvin »
Heather Galvin
Offline 1bigtracker
  • 3409
Re: I wrote a budget 4 door lift article..
« Reply #6 on: June 09, 2004, 08:31:36 AM »
my 93 2 door has a shaft with out a slider joint in it.  some do, some don't.  i had to take my shaft out and weld an socket into it to make it right.
stu
TITAN
« Reply #7 on: June 09, 2004, 09:27:08 AM »
why did u use xj or tj spacers...?
u can get 2 inch tracker ones at roadless gear...
http://www.roadlessgear.com/Merchant2/merchant.mv?Screen=PROD&Product_Code=SM-CS-001&Category_Code=SU&Store_Code=RGL
« Last Edit: June 09, 2004, 09:28:22 AM by TITAN »
Offline explosivo
  • 3157
« Reply #8 on: June 09, 2004, 10:17:41 AM »
Dead link for me :(
omghi2.us[/url]
Offline ed oorklep
  • 637
  • 1992 Suzuki Vitara
    • Suzuki Vitara 4x4
« Reply #9 on: June 09, 2004, 10:29:02 AM »
Haven't read it completely yet but I think it works on 2 doors as well, did mine about the same way (only without spring spacers, YET). And for the air filter hose being to short thingy, I put on an open air filter..... and soon a snorkel  ;D
BUT I like this page and will send it to everyone who ever has a question about body-lift or spacer lift  ;D THANKS Heather  ;D
http://www.suzukivitara4x4.nl
1992 Suzuki Vitara
ARB Bull Bar.
3" Suspension lift.
TITAN
« Reply #10 on: June 09, 2004, 10:38:03 AM »
Dead link for me :(
works for me? ???
Offline 1bigtracker
  • 3409
« Reply #11 on: June 09, 2004, 10:41:57 AM »
oh about the air filter tube, i used one of the tubes off a 5.0 F-150.  you just cut it to lengh and work it over the out and inlets.  i used some oil to help it over.
stu
Offline hcgalvin
  • 1695
    • Granite Path
« Reply #12 on: June 09, 2004, 11:07:20 AM »
Because, (if you don't like to wait for shipping...) you can find XJ or TJ coil spring spacers at most ANY 4x4 shop in any town, and they usually carry them in STOCK. And... I find they have been cheaper for me.
Heather
Heather Galvin
TITAN
« Reply #13 on: June 09, 2004, 11:11:41 AM »
makes sense i never thoght about that one,....
Crabzuki
« Reply #14 on: June 09, 2004, 11:33:42 AM »
stu
Stu here's what I did for the steering linkage and my welding's not bad either looked like a roll of nickles around the shaft, then I grounded the welds down and painted it black. If you have a spare shaft laying around I'd do it again for you. - CZ
Not bad since I haven't done any welding since 1995.  ;D
