how expensive?
  • 2151 Views
how expensive?
« on: October 31, 2010, 09:37:19 AM »
how expensive is it to add power steering to 86 sami?
Re: how expensive?
« Reply #1 on: October 31, 2010, 03:10:27 PM »
depending on how much you fabricate yourself, $200-400
should do it
Offline jawman
  • 406
  • 1234
Re: how expensive?
« Reply #2 on: November 02, 2010, 10:22:38 PM »
can't you just bolt a trackick steering box right up? then just figure out something for a pump.
87 Sami tin top
91 4 door SOLD
93 4 door
95 4 door
95 Geo 2dr V6
keep them coming
Re: how expensive?
« Reply #3 on: November 03, 2010, 12:03:44 PM »
No, you would need to drill out your frame or build a new mounting system.
Offline z3ro
  • 339
Re: how expensive?
« Reply #4 on: November 03, 2010, 06:41:15 PM »
LowRangeOffroad.com has everything you need.
You can source the pump, steering box, reservoir, brackets, lines, etc from a junkyard.  I paid $25 bucks for all that from my local yard.
You'll then need a v-belt pulley, frame bracket and rag joint eliminator (or use the sidekick steering shaft).
HTH
