Stuck Front break caliper piston
  • 1937 Views
Offline garyvd
« on: October 31, 2010, 04:23:45 PM »
My left front wheel was dragging after I repacked the wheel bearings and replaced the axle seal on my 87 sammi  tin top. I took the calipers apart and tried to free the piston. Its absolutely stuck. The manual says to use air pressure but after about 40 lbs didn't budge it I tried to bang it out from the back through the fluid hole with a drift pin. Its not budging and I'm hesitant to hit it too hard and bust the piston.
Any ideas or is it too far gone and need to be replaced. Can you buy just the caliper body or do you have to replace the whole brake assembly? I doubt its cheep.
Thanks Gary
Re: Stuck Front break caliper piston
« Reply #1 on: October 31, 2010, 05:02:31 PM »
Just get a new caliper, do both sides, they aren't that much
Offline ack
  • 1659
  • Professional askhole
    • Ack's FAQ
« Reply #2 on: November 01, 2010, 04:02:26 AM »
Also, do a search for caliper at Ack's FAQ to find a link to an article at izook.com on how to rebuild it...
Ack
Offline Jackdar
  • 26
« Reply #3 on: November 02, 2010, 06:41:06 AM »
I can get them at NAPA for 43 bucks each
1994 Geo Tracker 2wd
