Killed My Starter. Help? So I hit a HUGE puddle today in my 1998 Chevy Tracker.
  • 2912 Views
Offline umiami80
  • 39
So I hit a HUGE puddle today in my 1998 Chevy Tracker. I then stopped to get gas. Nothing when I tried to start. The Battery is fine, powers everything. So I push start. Happened again just now.
Did I kill it or is it something else?
Thanks.
__________________
1998 Chevy Tracker 5Speed 4WD, only options that are acceptable IMHO.
Could be dirt in the solenoid so it won't engage
or you knocked the small wire off the terminal
that makes the solenoid kick to life
Offline tuxblacray
  • 20
    • Tuxblacray Photos
Start with something simple. Remove your battery cables and clean them / remove your ground cable and clean it and the block attaching point / remove the wires to the solenoid and clean them. If you have the "clicky fix" on your solenoid remove the ground wire and clean it and the grounding point.
If that doesn't work then get out the OHM meter and touch the battery posts.  to see if your battery is discharging. If it still won't start I would guess that your solenoid is shot.
Does it click or anything?
        Tux...  :-\
« Last Edit: November 05, 2010, 01:33:37 PM by tuxblacray »
Offline z3ro
  • 339
Jump the terminals on the starter.  If it starts up, then start from the starter and work backwards.
Offline tuxblacray
  • 20
    • Tuxblacray Photos
If you do this and it starts it is either the solenoid or the starter itself. Majority of the time the solenoid is the culprit.
        Tux...
« Last Edit: November 07, 2010, 02:58:31 AM by tuxblacray »
Offline vw505
  • 133
YA i was stuck in a parking lot for like 30min with that damb wire!
Offline umiami80
  • 39
!!!!!!!!!!!!!!!!!!!!!!!!12/16/2010 UPDATE!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
All I had to do was jiggle the starter cable and it stated ???
That's it.
Time to clean and lube thos connectiions with dielectric grease! ;)
