CEL on now how too fix code 24
  • 12 Replies
  • 4549 Views
Offline beagle..t
  • 1239
  • 16
« on: November 06, 2010, 03:42:15 PM »
OK so a while back cel came on (91 tracker 1.6 8v) ......long story really short ran a jumper wire from b to c to check what code could come up # 24 which is (vehicle speed sensor)which means VSS faulty or broken speedo cable.Well speedo cable not broken is it possible that there is a sensor that the speedo hooks up to and that is faulty tired of lookin at that light on dash thx
Re: CEL on now how too fix code 24
« Reply #1 on: November 07, 2010, 02:29:26 PM »
The VSS is a reed switch on the back of the speedo head.
Offline beagle..t
  • 1239
  • 16
« Reply #2 on: November 07, 2010, 03:20:06 PM »
so i just buy another reed switch or do i just buy another speedo cable?
« Reply #3 on: November 07, 2010, 07:35:04 PM »
So what goes out, the reed switch or the magnet that makes it move?
« Reply #4 on: November 08, 2010, 04:27:49 AM »
Usually the reed switch fails, they have a limited life expectancy.
Offline beagle..t
  • 1239
  • 16
« Reply #5 on: November 08, 2010, 06:57:17 PM »
so new reed switch or ?
« Reply #6 on: November 08, 2010, 07:02:05 PM »
Ya, reed switch, if you can find the right replacement, or if you
are feeling real adventurous you could convert it over to an all
electronic input like a reluctor  wheel or ??? Can't think of the other
magnetic pickup type, brain tired tonight
« Reply #7 on: November 09, 2010, 12:35:08 PM »
Hall effect  ;D
Offline beagle..t
  • 1239
  • 16
« Reply #8 on: November 09, 2010, 06:35:50 PM »
ok will try auto parts store this weekend and see if i can get it fix thx guys
« Reply #9 on: November 09, 2010, 07:39:44 PM »
Thanks Rhino, I knew you could take up the slack for me, The auto parts store
isn't going to have that, you need an electronics store, like Digikey or some other
that has parts for sale, probably not RadioShack as most of them are just selling
electronics, not parts for electronics.
Now that I think about it, Hall Effect would be the best way to go, a reluctor wheel
is like what Ford is (or was, I'm not sure) using for their electronic distributorless
ignition systems, hall effect is what the electronic distributors use to trigger the
ignition spark
« Last Edit: November 09, 2010, 07:49:44 PM by wildgoody »
Offline beagle..t
  • 1239
  • 16
« Reply #10 on: November 11, 2010, 05:00:55 PM »
 a new speedo cable have this part as we dont have anything up here in canada like that or can i use a speedo cable from a ford ?
« Reply #11 on: November 11, 2010, 05:56:57 PM »
No a Ford cable won't work
Offline beagle..t
  • 1239
  • 16
« Reply #12 on: November 12, 2010, 08:01:25 PM »
if i dont fix this will it affect performance or anything cause i can just take the light out but would like too fix could i get a reed switch from another donor?if i knew what it looked like maybe ?
