2.0 crank position sensor location?
  • 5163 Views
Offline suva
  • 35
« on: November 07, 2010, 08:58:00 AM »
Where are they at? The old lady's 2000 4 door is throwing code po335. I've been told it's behind the flexplate, behind the crank pulley and on the back of the head. I'd just buy a sensor and look for it but I don't feel like pulling the tranny to replace it if that's where it is.
Offline Novadon
  • 205
  • South Carolina. USA
Re: 2.0 crank position sensor location?
« Reply #1 on: November 07, 2010, 10:16:42 AM »
You've got the location down (back of the engine, block area and pull the engine to replace), but they rarely (if ever) fail.   In all likelihood it's a bad wiring plug / connection or a chafed (shorted / parted) wire. Investigate that closely before you suspect the sensor proper.
 P0335 CKP Sensor Circuit Malfunction    ;)
« Last Edit: November 07, 2010, 10:20:51 AM by Novadon »
03' Honda Odyssey
Offline suva
  • 35
« Reply #2 on: November 07, 2010, 10:52:03 AM »
Thanks... Any idea what the plug looks like/how many wires go to it or where the plug is located?
Offline Novadon
  • 205
« Reply #3 on: November 07, 2010, 01:18:29 PM »
Can't help you there or I would. I've got the 2.5 V-6 and it's in a totally different area. I'll bet someone else will chime in though that has a 2.0.   ;D
03' Honda Odyssey
Offline LeeBuilt
  • Nevada Zuki Central
    • ZukiEngines
« Reply #4 on: November 30, 2010, 07:46:45 PM »
wow never thought I would be able to speak on this....BUT
I just bought some cores from the Head Honcho here and 1 of them was a 2.0
I will go out to the garage and get the sensor and take some pics. I have the block (it was trashed) but the sensor was there, I'll get a pic of the block too so you can see where its at!!
Zack
888.537.1307
Surgeon General said NOTHING about smoking the competition
