Gear grinding noise...87 samurai
  • 2302 Views
« on: November 16, 2010, 10:30:37 AM »
i have a very loud grinding sound coming from either the tranny or t case on my 87 samurai. It only happens when its in gear and when I an decellarting (not giving it gas...like when you are going down hill)....i have checked the oil level on the tranny and t case both are good. shifters stay in place the whole time.
Some one told me it was the t case going bad and that i could rebuild it and it would be fine. Any way I can check to make sure its the t case before I spend the money to fix it
Thanks
Brian
Re: Gear grinding noise...87 samurai
« Reply #1 on: November 16, 2010, 06:23:50 PM »
Is there any vibration at the time?  Does it make the same noise when your coasting in neutral or is it only when you are in gear and off the throttle?
« Reply #2 on: November 17, 2010, 02:19:50 AM »
yes there is a vib when it happens. and its only when im in gear and coasting. when it happends I put it in N and it goes away....
« Reply #3 on: November 17, 2010, 01:47:29 PM »
The vibration when you are not on the throttle sounds like bad u-joints.  Not sure about the grinding noise though.
