lock-rite backlash
  • 2494 Views
Offline tracker8wr
  • 568
  • THE BIGGER THE BETTER
    • my home page
lock-rite backlash
« on: June 14, 2004, 10:00:08 AM »
the instructions did not say anything about setting backlash and my haines manuel doesn't have any info on it. what should it be and how do i measure it and set it.
4 1/2 body
Coil spacers
cheap but effective
31" LTB Swampers
Offline tracker8wr
  • 568
    • my home page
Re: lock-rite backlash
« Reply #1 on: June 14, 2004, 10:39:33 AM »
come on guys im in the middle of my build a little help please.
4 1/2 body
Coil spacers
cheap but effective
31" LTB Swampers
Offline xamtex
  • 72
« Reply #2 on: June 14, 2004, 10:43:07 AM »
if you follow the lockright install manual TO THE LETTER then you dont need to reset the backlash.read the manual,follow every step in the book exactly and it will go back as it came out.
god must love crazy people,he made so many of them!!!
Offline xamtex
  • 72
« Reply #3 on: June 14, 2004, 10:46:07 AM »
the lockright install manual is wonderful.you need to follow it exactly.any problems then ask/email me,
carslet|removethispart|@aol.com
Offline tracker8wr
  • 568
    • my home page
« Reply #4 on: June 14, 2004, 12:09:11 PM »
thanx for the info just had to quit worring and do it. we finish my friends abd will do mine in alittle while.
4 1/2 body
Coil spacers
cheap but effective
31" LTB Swampers
Offline xamtex
  • 72
« Reply #5 on: June 14, 2004, 12:15:15 PM »
the first one i did i was stressing over the backlash,but it came out ok,ive done a few now and no problems.
if the backlash is about right before you start then its ok when you finish.
rock the crown wheel to get a feel of it and as long as it feels about the same after fitting then you will be ok.
« Reply #6 on: June 14, 2004, 12:21:37 PM »
My low 5.83s that I got from Heather were
set to .008" by Trail Tough, so the ring gear
(crown) should move .008-.010" with a dial
indicator set up touching the ring gear teeth
The most important setting is the pinion depth,
but if you didn't change gears and just installed
the locker, adjust the back lash to meet the 8-10
and you should be good.
