XL7 2.7l Thermostat Location
  • 1830 Views
Offline jagular7
  • 1026
  • Jagular7
« on: November 21, 2010, 04:30:59 PM »
I had a CEL show up (P0128 IIRC) and told that the engine doesn't run up to engine temp. Followed the top hose off the radiator and the housing looked real small for a thermo.  Pulled the cap anyways, and no thermo. It got too dark even with a light. Followed the lower hose off the radiator and it goes from rubber to steel tube to a connection with a housing that looks big enough for the thermo. Is the thermo located under this? Its located under the top hose connector.
Lenexa, KS
Offline sir lance
  • 342
  • I love my XL-7
Re: XL7 2.7l Thermostat Location
« Reply #1 on: November 21, 2010, 10:01:08 PM »
its under the larger housing that goes to the lower rad hose, (the one that sits right beneath the upper rad hose housing.
-Lance
Offline jagular7
  • 1026
  • Jagular7
« Reply #2 on: November 22, 2010, 08:08:52 AM »
Thanks. That was my guess. I really don't want to loose too much antifreeze when I do this. It has 112k miles on it and all original cooling. I planned to flush this spring and want to use distilled water/coolant than my hard water from my house.
Lenexa, KS
Offline Maiden Hell
  • 1650
  • MAIDEN HELL!
    • My Space
« Reply #3 on: January 15, 2011, 09:07:01 PM »
I've gotten the same code twice on snowy mornings up here where I live.  Never hardened before.  I'm not in the mood to change it this time of year and it's not that serious of problem.
