Technical Discussion - Beginner / Repair
No fire to my 87 Sami
c3006
263
10
November 30, 2010, 10:23:04 AM »
I have a 87 sami stock that was not getting fire. I swaped out the coil and distributor with known good ones. Then I noticed that I have no idiot lights when I turn the key to start it. Is there a fuse that could be keeping me down? thanks c
c3006
263
10
Re: No fire to my 87 Sami
November 30, 2010, 01:54:57 PM »
I ran a jumper from the positive batt term to the positive coil lug and all the idiot lights came on and it fired right off and ran but still cant find out why the coil has no fire when the switch is on???
wildgoody
8134
67
November 30, 2010, 02:24:06 PM »
Check the power relay under the dash, or the fuses
that are under the hood, big square ones, they supply
power to the rest of the truck, the should be close to
the battery, or at least have some big wires on them
c3006
263
10
Reply #3 on:
November 30, 2010, 03:38:39 PM »
The haynes manuel is a waste on electrical guidance,where in general would you find the power relay under the dash? thanks c
wildgoody
8134
67
Reply #4 on:
November 30, 2010, 11:13:06 PM »
Close to the inside fuse block, you should hear some clicks from
under the dash when the key is turned to the on position, no clicks
then I think you don't have power to the relay
