tracker running rich
  • 3975 Views
« on: November 30, 2010, 06:43:30 PM »
Hi my 95 tracker is running really rich. any ideas whats causing it?
Re: tracker running rich
« Reply #1 on: November 30, 2010, 11:18:37 PM »
Start with the basics, new air filter, check to make sure the hose to the MAP
(8V engine) is connected, and then change the O2 sensor, you might also
have a bad coolant or air temp sensor, but less likely
Offline beagle..t
  • 1239
  • 16
« Reply #2 on: December 01, 2010, 04:58:26 PM »
what wild said rich running usually O2 sensor or could be catalytic converter
« Reply #3 on: December 01, 2010, 05:42:09 PM »
thanks guys,
replaced the temp sensor in spring. is it worth buying a k and n filter?
« Reply #4 on: December 01, 2010, 06:32:25 PM »
Not to fix the running rich problem.  The K&N is nice, give you a bit quicker throttle response, but your not going to see much of a power gain.  A short ram kit will give you a better response, but I like the stock airbox so I don't have to worry about water or mud.
