Technical Discussion - Beginner / Repair
diagnostic codes
diagnostic codes
bodyman
10
diagnostic codes
December 11, 2010, 08:25:14 AM »
Hey guy's I'm new to the site I've been searching threads the last couple weeks and found some great info. I am new to zuki's all together I'm a body/frame tech by trade and I'm used to dealing with obd1 and obd2 systems.My question is I have a check engine light on in my 90' Samurai and I put a 20 amp fuse in the diagnostic space in the fuse box under the drivers side of the dash and connected a jumper wire to the #2 and #3 pins on what I believe is the diagnostic terminal I located it behind the battery but I'm unable to read the codes the light just stays on solid here is a pic of the terminal I found do I have the right one or am I doing something else wrong?
thanks for all your help.....Jason
bodyman
10
Re: diagnostic codes
December 11, 2010, 01:26:10 PM »
Got it figured out there is a switch under the dash on the drivers side that had to be flipped with a fuse in the diagnostic slot read a code 12 which is a systems normal code. I unhooked the battery cleared it and now it's off
Skyhiranger
3734
122
I don't buy, what I can build
December 11, 2010, 02:25:20 PM »
Glad you got it figured out.
Also, you only need to either put a fuse in the diagnostic slot, OR put the jumper in the plug by the battery, to check for codes.
bodyman
10
Reply #3 on:
December 11, 2010, 03:33:35 PM »
yeah I figured that out I'm lucky I didn't fry my ecm going at it like I was, I really like my rig but these things are a learning curve from what I have dealt with over the years
Last Edit: December 11, 2010, 03:35:08 PM by bodyman
