Transfer Case Gears
  • 14 Replies
  • 3701 Views
Offline Rod
Transfer Case Gears
« on: June 10, 2004, 07:50:00 AM »
I just received my transfer case gears for my 1990 Sidekick (I ordered them from Calmini in April).
When I opened the package the instructions said they where good for 93-98 Sidekick/Trackers.  I called Calmini and they said that the transfer cases changed in 93 and I would need to get a 93 or newer transfer case.  I wish they would have told me that when I ordered them (and when I told them I was going to install them into a 1990 model).
Has anybody else had this problem?
Rod
Rod
  • 6598
  • 68
Re: Transfer Case Gears
« Reply #1 on: June 10, 2004, 09:19:20 AM »
Rod
You do need the newer t-case. Try your local junk yard or pick-a-part, they'll basically give you a Sidekick t-case, at least that has been my experience....
Good Luck, -Eric
Offline Rod
« Reply #2 on: June 10, 2004, 10:25:57 AM »
Thanks,
Will the 93-98 Sidekick transfer case bolt right right up to a 90 transmission?
What do I look for to verify if the donor transfer case is good or not?
Rod
Rod
Offline Natebert
  • 1098
« Reply #3 on: June 10, 2004, 10:58:50 AM »
Thanks,
Rod
It bolts right in, don't know what to look for.
~Nate
Offline TomKat
  • 211
« Reply #4 on: June 10, 2004, 12:44:57 PM »
Yeah, Rod. They did the same thing to me. When I told the guy I had an '89, he SHOULD have TOLD ME I NEEDED A '92 and up 'case. I then call and get someone else on techline, and basically got an attitude for trying to put them in an '89 case. Needless to say, I haven't ordered anything from them since!
88.5 Sammy,YJ's,33's,Yota axles,4.9-1 'case,dents and rust...
Offline Mikerpm4x4
  • 2875
  • Redline... all the time!
    • www.rpm4x4.com
« Reply #5 on: June 10, 2004, 01:03:10 PM »
Here is a link to their website.
http://www.puresuzuki.com/rockcrawler1.htm
It clearly states that it only fits 93 - 98 cases right next to the price. I dont think its fair to expect the person on the phone to explain everything about thier product before you buy it.
Mike
« Last Edit: June 10, 2004, 01:04:58 PM by Mikerpm4x4 »
Offline safarikick
  • 270
  • nor-cal rhinos
« Reply #6 on: June 10, 2004, 01:31:55 PM »
no  :o
Finally, a true ROCKCRAWLER Transfer case gear set for for the Sidekick and Tracker.  Our gear set is manufactured in the USA from SAE 8620 alloy billet material. We believe that welded gears are JUNK! For long wear life and vibration free operation at high speeds nothing else is acceptable. Final reduction of 4.24:1 is a whopping 134% lower than stock! When used with the stock axle ratio of 5.12, it yields a crawl ratio of 79.3 :1!  If you look around, the only Sidekicks/Trackers you find really doing it off road run a CALMINI ROCKCRAWLER! There's a reason!  It completely transforms this vehicle's off road capability. Complete kit comes with all new machined billet gears, bearings, seals, 2 quarts of oil and installation instructions for an easy do it yourself at home installation.
VEHICLE                  PART NUMBER                    PRICE
1990-98        Sidekick / Tracker SK5047               $975.00
that is off of the link
« Last Edit: June 10, 2004, 01:33:10 PM by safarikick »
Offline Rod
« Reply #7 on: June 10, 2004, 02:13:20 PM »
When I called and ordered the transfer case gears I specifically asked if they fit a 1990.  That particular saleman said "Yes".  When I called back today the salesman said "no". He did quickly offer to let me ship them back for a full refund.  I want to see how much a used transfer case is going to cost first.  When I ordered the gears in April they where on special for $875.  So maybe the money I saved will help offset the cost of another transfer case.
Rod
Rod
« Reply #8 on: June 11, 2004, 12:07:41 AM »
I was considering replacing the tcase gears. I have a spare tcase that I was going to put the new gears in, that way I would minimise the time I was without the car. I don't recall the year of the truck that the tcase came from. Is there any way to tell?
Offline TomKat
  • 211
« Reply #9 on: June 11, 2004, 01:13:04 AM »
Mike
I had no computer at the time I ordered mine. I got the # from a friend over the phone. I would EXPECT them to know thier product, especially when they specifically asked me what year I had. If he told me on the phone I needed a newer case, no problem. I have a couple kicking around. I just didn't care for the attitude I got from tech assistance. I'm not looking for a detailed explanation of the gears, just if they'll fit the year track/kick I had, I don't think that's asking a lot.
Offline Natebert
  • 1098
« Reply #10 on: June 11, 2004, 07:04:25 AM »
I'd think a used case from a junkyard would be pretty cheap.
~Nate
Offline tracker8wr
  • 568
  • THE BIGGER THE BETTER
    • my home page
« Reply #11 on: June 11, 2004, 09:56:06 AM »
i got a trnny from hawk for $250 no shipping. they like calmini and may help u out once u explain to them what happened.
4 1/2 body
Coil spacers
cheap but effective
31" LTB Swampers
Offline Mikerpm4x4
  • 2875
    • www.rpm4x4.com
« Reply #12 on: June 11, 2004, 11:20:48 AM »
no  :o
I just clicked on it and we are both wrong. It says 91-98
Mike
Offline safarikick
  • 270
  • nor-cal rhinos
« Reply #13 on: June 11, 2004, 02:25:28 PM »
no  :o
that was off the web.  it is not the same as it was on 6.10.2004. it looks like they change it
TITAN
« Reply #14 on: June 11, 2004, 02:36:14 PM »
do u they have a guy to check all the boards to see what people want for thier zuks??
