rear diff rotate question
  • 2289 Views
Offline adamsobi
  • 43
« on: December 14, 2010, 03:05:48 PM »
im planing on doing the hagen widening and rotate mod. but have a question about the 3rd link. do i do the same as the rock sready lift. i only have 1" coil spacer
1997 Sidekick
2" body, 1" coil spacer
31x10.5 r15 toyo mt
custom tube bumper
Re: rear diff rotate question
« Reply #1 on: December 14, 2010, 03:52:42 PM »
When I did mine in order to get the correct angle on the driveshaft, and get the advantages of the overation, such as moving the axle back a bit my center link spacer had to be offset to work.  The bottom 4 bolts of the spacer that bolt to the top of the diff and the top 4 holes that bolt to the center link only share the hole spacing in the middle holes. --   something like this if your looking at the spacer from the side.  Hope that makes sense.                                                           --
Offline adamsobi
  • 43
« Reply #2 on: December 14, 2010, 04:04:31 PM »
is this mod even worth it with only 1" of lift? also is the widening mod not a good idea on a daily driver?
1997 Sidekick
31x10.5 r15 toyo mt
custom tube bumper
« Reply #3 on: December 15, 2010, 04:33:08 AM »
with only 1" of lift it's not really necessary, either is the whole widening mod if your using it mostly as a daily driver. there are some great advantages to doing the mod, especially if you want to run bigger tires, 32/33", but otherwise, IMO, no.
Offline adamsobi
  • 43
« Reply #4 on: December 15, 2010, 02:49:57 PM »
i thknk i might just do the rotate mod for now. if were to raise the spring mount that should give me a little lift in the rear right? my rear end sags alittle as it is so that should help
1997 Sidekick
31x10.5 r15 toyo mt
custom tube bumper
« Reply #5 on: December 15, 2010, 03:41:09 PM »
You'd probably be better off just replacing the coils, the diff rotation isn't going to give you any lift, and with sagging coils you might actually loose a bit. Raising the spring pad is a way to get some lift, and you have to cut them off when you do the rotation and re weld them anyway, it may help.
