Towing 87 4x4 4down
  • 9 Replies
  • 2600 Views
Offline Hard_Top_Sam
  • 10
  • My Tin Top w/o A/C
Towing 87 4x4 4down
« on: June 09, 2004, 02:54:53 PM »
It says in the manual that I can tow 4 down. Transfer Case in Netural, Trans in 2nd, key on Acc. to unlock the steering wheel. Is there a fuse I can pull so the clock and the clock on the radio don't work? Or do I just disconnect the negtive on the battery and live with it that way!!!!
One Day I will Learn all about this new TOY I have
Offline 87BlackSami
  • 191
  • http://www.quic kvwbug.4wdriver .com/
    • http://www.quickvwbug.4wdriver
Re: Towing 87 4x4 4down
« Reply #1 on: June 09, 2004, 03:10:36 PM »
I wouldn't worry about the clock running your battery dead since even with the key off the clock is still on just not illuminated. It would take weeks or months for it to run down the battery. With the radio just manually turn it off.
Also if your flat towing I recommend every 70 miles or so start the sami in 2wd high and neutral to circulate some oil in the tranny.
locked,5.8:1 Tcase, 5.12's, 35x12.5Xterrain's, 4" BDS L/O, Ford towers, 5-8" shackles w/reverse, tracbar, Yota P/S, diffs capped, skidplates, onboard air, fabbed bumpers & shafts, Herculined, airhorns
« Reply #2 on: June 09, 2004, 03:26:49 PM »
BUT. if your towing really far.(over 100miles) Drop the driveline and don't worry. You'll feel much better ;D
  • 10
« Reply #3 on: June 09, 2004, 04:51:34 PM »
I am going from Calif to Oklahoma and it says in the manual that I can go 200 miles before I have to start the engine and run it in 2nd with the clutch engaged. hmmmmmmmmmmmmm
Offline Ronzuki
  • 261
  • What's a Samurai?
« Reply #4 on: June 09, 2004, 11:42:24 PM »
Drop the rear shaft....it only takes a few minutes, then nothing is spinning.  Flat towing the way the manual states is OK for really short jaunts but be aware that the front driveshaft is spinning.
'91, RRO Bolt-On SPO, 32" BFG Muds, 2" BS U.S. Wheels, Breeeze CO, Neon Seats, 5.8:1 T-Case, TT Mighty Kong Bucket, 1.5" RUF, 1.5" Rears, DT Shocks, RRO Sliders ,Rear DetroitEZ, OBA,Celica PS
RCrocs Team 509
  • 10
« Reply #5 on: June 10, 2004, 12:59:19 AM »
When you say drop the REAR drive shaft do I drop the front of it or the back or both ends and put it the back of my Zuki?
Thanks
Offline 87BlackSami
  • 191
« Reply #6 on: June 10, 2004, 03:43:00 PM »
At the least disconnect it from the rear axle or to be completely safe unbolt it all together.
Offline Ronzuki
  • 261
  • What's a Samurai?
« Reply #7 on: June 10, 2004, 11:57:28 PM »
Thanks for clearing that up 87  ;) ... I took mine completely out.
RCrocs Team 509
Offline Somer
  • 143
  • Hey, is it suppose to do that!!
    • D2
« Reply #8 on: June 11, 2004, 04:22:31 AM »
Just wondering, but why do you  have to put the transmission in to 2nd? Why not neutral?
Offline trackermad
  • 150
« Reply #9 on: June 11, 2004, 05:13:29 AM »
I think its just to keep the tranny from spinning so you don't have the same lubrication probs in there.
"First of all: what is work? Work is of two kinds: first, altering the position of matter at or near the earth's surface relatively to other such matter; second, telling other people to do so."  ~Bertrand Russell
