body lift on vitara
  • 4058 Views
0 Members and 15 Guests are viewing this topic.
Offline mrphil
body lift on vitara
« on: December 20, 2010, 05:03:32 AM »
Hi all,
im new here, so hello, names phil and im from south wales, uk!
Ive been out of the offroading scene since 2007, when i sold my vitara due to personal circumstances. im now wanting to come back, and have a few questions.
ive attached a photo of my old vitara, not sure what it had to be honest as i bought it all ready kitted out!
im wanting to get it up in the air, now whats the difference with just a body lift? and then suspension lift, and both?
Ive heard alot of talk about peoples driveshafts causing problems and breaking.. so could i lift the body say 5 inches, and keep the standard suspension?
Im also looking to come wide, so to have a nice wide track, would 38mm spacers do the trick, id also be looking to run 31 inch tyres....
is there a big difference in a lwb 5 door to the swb 3 door vitara?
With lifting the body what is needed, ive seen these nylon plastic spacers for the top of the suspension?
Basically after some good info... also aware i need to extend the brake lines - would i need to buy new longer braided ones? and also the fuel tank, is it ok to be left where it is or should i lift it in to the boot?
Thats all for now, hope i can have help  :)
Merry xmas!
ps. my old vit kept chewing the half shaft is there a reason behind this?
Re: body lift on vitara
« Reply #1 on: December 20, 2010, 09:11:58 AM »
Looks like you have a body lift and a suspension lift on that truck,
but without pics from under the truck, there is no way of knowing
if you had a Calmini kit or another knockoff, or just a modded stock
system, which is what I have done.
I suspect the problem you were having with halfshafts was a home
grown kit that over lifted the front suspension, or perhaps someone
did a strut mount flip after the suspension lift. The stock front inner
CVs can only take a 3" maximum lift past the stock fully extended
suspension cycle, I would tell you to only go to 2-3/4" for CV life
Offline mrphil
« Reply #2 on: December 20, 2010, 11:35:48 AM »
thanks for the reply!
that was the only two photos i could find of my old vit  :(
I replaced the halfshaft and the same day it chewed its splines again!
Right, so to say, my driveshafts would be safe at a 4 inch lift - calmini 2 inch lift kit, and then a 2 inch suspension lift?
ive seen this suspension kit - not sure if its any good? couldnt find a calmini one, they only sell the body lift kit (2inch)
http://cgi.ebay.co.uk/SUZUKI-VITARA-3-LIFT-KIT-SPRINGS-SHOCKS-SPACERS-BUSH-/280600504354?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item415517e822
ive also found a set of 32mm spacers, has anyone got a picture of a vit lifted 4 inch with 32mm spacers? just so i can get an idea...
thanks
« Reply #3 on: December 20, 2010, 08:09:41 PM »
That's kind of expensive for 4 springs 2 shocks 2 strut spacers and a bushing kit.
Also the Toe not the Tow will be affected, I suggest you talk to Jeff here
on the board, get some spacers and buy the shocks locally, save a bunch
of cash and get the same results
