No spark
  • 2604 Views
No spark
« on: December 24, 2010, 03:10:32 PM »
I just bout an 88 suzuki samurai it does not have any spark where do I start? It has power to the coil and out of the coil to the little box behind the coil. It has power going to the distribitor.
Re: No spark
« Reply #1 on: December 25, 2010, 08:06:00 AM »
It's probably a good idea to swap in a known good distributor
to rule out any other parts, it's likely the ignitor inside the distributor
Offline c3006
  • 263
  • 10
Re: No spark
« Reply #2 on: December 25, 2010, 11:34:27 AM »
Check to see if you have fire comeing out of the coil going into the distributor cap, if so then it is cap or button. If not then distributor is next in line.  Good luck  c
Re: No spark
« Reply #3 on: December 26, 2010, 09:56:19 AM »
After looking a little closer this thing has to be a 91 up it is efi and all the pics of the ECM I fine that looks like mine are 91 up. hope this helps.
Offline c3006
  • 263
  • 10
Re: No spark
« Reply #4 on: December 27, 2010, 09:57:22 AM »
If you have power at the coil and no fire coming out of the coil to the top pf the distributor then it almost has to be the ignitor in the distributor. Pull the coil wire out of the top of the distributor and hold the end close to a ground(without touching it :)) While someone turns it over and see if fire is going to the rotor button.  Good luck   c
Re: No spark
« Reply #5 on: December 27, 2010, 06:17:16 PM »
Got no spark at the coil while cranking. Had my son in law hold the coil wire  >:D and he never screemed.  There is a little box behind the coil that sez ignitor on it. would it be this or the pickup in the distributor. Thanks Bob
« Last Edit: December 27, 2010, 06:23:55 PM by hollywood514 »
Re: No spark
« Reply #6 on: December 27, 2010, 08:24:51 PM »
It's the ignitors that go out, I would try that first, but don't buy any
new parts, see if you can find used ones or borrow if you can until you
figure out the problem.
The truck didn't happen to run and someone pulled the battery cable
off to check the alternator did they?
Re: No spark
« Reply #7 on: December 28, 2010, 03:12:25 PM »
I found a guy with a running samurai and we took my Ecm, coil ,ignitor and pickup coil and put on his one at a time and it was the Ecmthat was bad. He go's by reracingatv on ebay he had the used part to fix it and many more. Super nice guy. Thanks for all the help. Bob
