BDS suspension
  • 2720 Views
Offline tracker8wr
  • 568
  • THE BIGGER THE BETTER
    • my home page
BDS suspension
« on: June 09, 2004, 08:47:42 AM »
does anyone run a BDS suspeneion. if so how does it ride. if not has anyone ever heard of them.
4 1/2 body
Coil spacers
cheap but effective
31" LTB Swampers
Offline safarikick
  • 270
  • nor-cal rhinos
Re: BDS suspension
« Reply #1 on: June 09, 2004, 11:04:28 AM »
a little stiffer on little bumps and railroad tracks. ;D ;D
work go off road with a 3in body lift you can get 31 on it
Offline tracker8wr
  • 568
    • my home page
Re: BDS suspension
« Reply #2 on: June 09, 2004, 02:37:46 PM »
i run 31 now with my 3" body and 1 1/8 coil spacers. i wanted the longer coils for more travel and to try to fit 34's. i am not a fan of the calmini 3 suspension because it is way to rough. i have to drive it almost every day to and from work it is only 3 miles of non-highway use.
4 1/2 body
Coil spacers
cheap but effective
31" LTB Swampers
Offline safarikick
  • 270
  • nor-cal rhinos
Re: BDS suspension
« Reply #3 on: June 09, 2004, 02:51:09 PM »
34 will not fix
ask 1bigtracker on the 34
Offline 1bigtracker
  • 3409
Re: BDS suspension
« Reply #4 on: June 10, 2004, 04:24:22 AM »
yea i knew you guys would end up asking me.  so here it is, how to fit 34's for cheap:
calmini 3in body lift
sawzall
welder
torch
LOTS OF TIME
i had to cut my floors out and build my own to clear them.  i have move them back aleast 6 inchs.  trim rear fenders as much as you can.  just cut the bottom of the  fronts.i'm not running a front bumper and my rear dosn't have the cover on it and alot of the stuff that was on it has been taken off.  you will need to cut the rear fender wels out if you want to get full flex with these tire cuz they rub and hit every where.  i would also extend the wheel base about an inch.  mabey this will give you an idea of the work to fit the rubber.
stu
Offline 1bigtracker
  • 3409
Re: BDS suspension
« Reply #5 on: June 10, 2004, 04:26:53 AM »
and you will need to do somthing about gears too if you don't want a REALLY sluggy tracker going down the road.
stu
Offline tracker8wr
  • 568
    • my home page
Re: BDS suspension
« Reply #6 on: June 10, 2004, 04:47:49 AM »
i do plan on putting a suspensension lift so i shouldn't have to as much cutting as u. i am also going to move the the front suspension up 2 or 3" the back will stay for now until i four link it. i just don't care to much for the calmini 3" suspension because of haw rough it is. thanks for all the input.
4 1/2 body
Coil spacers
cheap but effective
31" LTB Swampers
Offline 1bigtracker
  • 3409
Re: BDS suspension
« Reply #7 on: June 10, 2004, 07:38:21 AM »
i do have 2in coil spacers in front but that is because my front coils where saging.
stu
  ÂÂÂÂÂÂÂ
