starter problems
  • 2203 Views
Offline bugman
starter problems
« on: January 06, 2011, 05:56:34 PM »
hi eevrone im new to zuks and i don't have many conections for info. i have a 87 zuk with zuk trans ,adapter with 2004 roedo motor. starter won't line strightso i ground block and stsrter. sounds like its going to fall off when turning . draging bad. any ideas would realy help thanks bugman.
Re: starter problems
« Reply #1 on: January 06, 2011, 06:55:08 PM »
What flywheel did you use? Zuki or Isuzu?
I would think that the Samurai starter would be a better fit
on the trans bell housing
Offline bugman
« Reply #2 on: January 07, 2011, 04:48:00 AM »
 it  has zuk starter and flywheel that has been redrilled and cut .on crank side  motor .i have replace starer 3 times  groud motor block and starter for alignment.replaced flywheel ring . cut starter nose to sink further toward flyheel . i think it needs smaller dia sstarter . thanks for all the info i have been working on this for months. thanks bugman
« Reply #3 on: January 07, 2011, 07:38:06 PM »
My bad, I was thinking the Suzuki starter was on the trans bell housing,
the starter is in fact on the engine side. I change my statement, I think
you should be using the Isuzu starter so it matches the block and is the
right depth to reach the ring gear.
But I have to admit, I don't recall ever seeing an Isuzu Starter so I don't
know how it compares to a Suzuki one
« Last Edit: January 08, 2011, 02:25:07 PM by wildgoody »
Offline bugman
« Reply #4 on: January 08, 2011, 01:03:16 PM »
thinks for the input looking for starter now.bugman
Offline bugman
« Reply #5 on: January 08, 2011, 01:07:43 PM »
good idea looking for starter now. thanks bugman
