Engine Compression Test
  • 2360 Views
Offline Montaro
    • Montaro 4x4
« on: January 09, 2011, 02:15:11 PM »
Hello,
I want to share this article about the Engine Compression Test i made in my Tracker Gen 1 but could help or any engine you just need to check the Cylinder compression specification for your engine.
http://www.montaro4x4.com/eng/mecanica_art.php?id=15
I'm not expert, so if you have a useful comment that will be great!  ;)
« Last Edit: January 09, 2011, 02:16:44 PM by Montaro »
Montaro
The Ant
J1 96
 *Link Removed*
Re: Engine Compression Test
« Reply #1 on: January 09, 2011, 02:50:42 PM »
Two things ...
First - if the engine is fuel injected, you might want to disconnect the fuel injector harness as well as the distributor
Second - you need to block the throttle so it's wide open.
« Reply #2 on: January 09, 2011, 07:28:31 PM »
On a FI engine, when the throttle is wide open WOT at cranking speeds
it triggers the Flood Clear Mode, so no fuel is injected
