please help with lean condition.
  • 1986 Views
Offline KJMac
  • 280
« on: January 09, 2011, 07:50:02 PM »
My spark plugs are white! I have done everything but new injectors.
It has a header with 2 1/2" (too big) exhaust and w k&n filter in the stock box. I even put the injectors
In that were out of my old engine, no difference. It is doggie on the bottom, it has 235/75/15 tires, 4door and 5speed.
It is a '95 engine in a '94! I found some old plugs out of the '95 and '94 and they are white. Do I need new injectors?
Re: please help with lean condition.
« Reply #1 on: January 09, 2011, 10:17:03 PM »
Have you checked the fuel pressure? changed the fuel filter?
You might want to clean the MAF and check the Coolant and Air
temp sensors, that's more likely where the problem is
Offline KJMac
  • 280
« Reply #2 on: January 10, 2011, 10:39:35 PM »
Thanks for the response Wild!
I have done all of that....a couple times over. I changed the fuel probably when I didn't need to and the others to with
Change. I tried to exhaust all avenues before bugging you guys! Thanks!!
Kevin
« Reply #3 on: January 11, 2011, 08:29:33 AM »
You might want to try replacing the 02 sensor as well, I needed to swap mine out after an engine swap.
Offline KJMac
  • 280
« Reply #4 on: January 14, 2011, 09:29:36 PM »
Drone,
Thanks, I did do that too.
