transfer gears; towing
  • 1758 Views
« on: January 12, 2011, 12:39:09 PM »
What is the best all around gear ratio for the transfer case? I only cruise local streets and dirt no freeway for this sammi.
Also, when towing with a tow bar should the 4x be in N or 2h?
Re: transfer gears; towing
« Reply #1 on: January 12, 2011, 04:01:09 PM »
What kind of terrain do you plan on doing? Super low ranges are great for rocks and severe obstacles but may be too low for just trolling around the desert. Sometimes I find my low range too low, and high too high. It's like I need a gear or maybe 2 between 3rd in low range and 1st in high. So, freeways are out, good that decreases the choices. How big of tire do you run? Do you need or want to be able to spin it? Muddy and loose where you are? Best for one size could be worst for another. In most cases for just general blasting around the stock gears are fine, but if you really want a lower overall gear range, depending on the transmission type man or auto, you could go to a 4 to one low or combined to lower your OVERALL ratios. Have you changed anything else in the truck?
As for towing, what type of trans is it? Auto or Manual?
Offline truckpdlr
  • 23
« Reply #2 on: January 12, 2011, 04:14:30 PM »
If you are towing a Sami with a 5speed the manual says to have the transfer case in netural and the transmission in 2nd gear.
Leaving it in gear makes sure that the trans gets lubrication and the transfer case is never totaly out of gear speedo will continue to read.
Bone stock 87 Sammi
