Ford 9 inch questions
  • 10 Replies
  • 4505 Views
Offline adamsobi
  • 43
« on: January 13, 2011, 05:02:37 PM »
im thinking of doing the ford 9in rear swap. will i need to find gears to match the front, i have 5.12s or do i certain model fords have this gear ratio? also are there any selectable lockers available, or is ARB still my only option?
1997 Sidekick
2" body, 1" coil spacer
31x10.5 r15 toyo mt
custom tube bumper
Re: Ford 9 inch questions
« Reply #1 on: January 14, 2011, 12:08:35 AM »
There are a lot of options for the Ford 9".  You can go with Electric lockers or the ARB, but not OX for some reason, even though they have one for the 8.8.
Are you going to have your 9" cut down, go with a custom rear axle such as a Spider 9, or swap full width axles under both ends?
Offline adamsobi
  • 43
« Reply #2 on: January 14, 2011, 02:20:15 PM »
will i need to cut down the axels, from hagens report on it i dont think he had to.
1997 Sidekick
31x10.5 r15 toyo mt
custom tube bumper
« Reply #3 on: January 14, 2011, 04:03:41 PM »
Most likely.  Most 9" rear axles are taken from full sized vehicles, so they need to be cut down to fit.   F-150 9" axle is 65", compared to the 54" (I think) width of a Tracker.  So as long as your ok with your rear tires sticking 5" further out on both sides of your rig then you won't need to cut it down.
While it can be done on the cheap, if you plan on switching to 3/4 Ton running gear under your rig and to keep it in full street capable condition you really should plan for about $1000 per axle.
Offline beagle..t
  • 1239
  • 16
« Reply #4 on: January 14, 2011, 07:48:38 PM »
i believe that mustang II yr 74-78 that came with the 302 had the 9" and they are  narrow thats what mine had back in the day .......long,long time ago put the rear-end in pinto and v8 stupid fast
« Reply #5 on: January 15, 2011, 06:16:51 AM »
The old ford bronco's in the mid 70's would be the narrowest dana 44 front and 9" rear. But still much wider than a sammy
« Reply #6 on: January 15, 2011, 08:11:46 AM »
FWIW; no ox locker is available due to the lack of diff cover, the ox locker's shift rail is integrated in to the diff covers
« Reply #7 on: January 17, 2011, 09:20:34 PM »
Ah, that makes a lot of sense.  Thanks!
« Reply #8 on: January 18, 2011, 06:13:14 AM »
I found mine off of a Jeep CJ buggy that was upgrading axles. It was actually a little narrower than the Kick axle.
  • 6603
  • 69
« Reply #9 on: January 18, 2011, 09:02:50 AM »
Another thing to consider is that because the 9" is so well supported in the aftermarket, it may be better to get a completely new assembly vs. junk yardin'.
Offline fordguy79
  • 494
  • 8
  • long beach Wa,
« Reply #10 on: January 20, 2011, 10:20:14 AM »
you can get a 5.13 r&p set that would work    best of all if you had a front axle made too you can gear way down as low as 7.33
i want to build a set of axles for my sami  the wife keeps telling me its her or the sammy  and the sammy is staying  >:D had it longer :laugh:
http://www.ringpinion.com/PartsList.aspx?SearchMode=Diff&TypeID=4&DiffID=29&CatID=10
