front axle assy
  • 2340 Views
front axle assy
« on: January 17, 2011, 09:59:30 AM »
What front axle assy will fit a LJ80  are there other models that can use  like maybe the tracker ,sidekick or geo that would be close to the right width or any other 4x4 vehicles that I might be able to use the front axle.
« Last Edit: January 17, 2011, 11:40:31 AM by j860112 »
Offline Jordan
  • 161
  • Chrome don't get ya home, but it sure looks nice!
Re: front axle assy
« Reply #1 on: January 17, 2011, 06:08:17 PM »
A SJ410 would be close to bolt on, I know a guy that put the diff out of a 83 SJ410 under a 79 LJ80, my 82 SJ410 diffs are 50" wide drum to drum, 83 and up have disc brakes on the front diff, 82 and older have drums front and rear, but I think they are all 50" wide and have 410 R&P gears until 85 then they changed.
With the 83 front diff you would get the disc brakes and your LJ drive shaft bolt pattern is the same, in 84 they changed the bolt pattern.
Hope this helps.
82 SJ410: 5" lift (spoa), home made cross over steering, bestop, custom rust lots of it,33"tsl, 6.5:1's. To install: Toyota diffs being built. To build: roll cage, traction bar, bumpers.
89 sidekick: lift 2"suspension 3"body, 31's, aluminum rims, warn hubs, (4) lights on roof, turbocharger.
Re: front axle assy
« Reply #2 on: January 17, 2011, 06:36:54 PM »
Hope this helps.
Jordan is the differential centered on the sj410 thanks, JIM
Offline Jordan
  • 161
Re: front axle assy
« Reply #3 on: January 18, 2011, 01:11:51 PM »
No, its offset to the passanger side.
