what harley carb do I get?
  • 13 Replies
  • 5973 Views
Offline airmanwilliams
  • 913
« on: January 18, 2011, 06:31:41 AM »
I am looking to trade or sell all my spare parts off so I can get a myside kit but if I end up getting one without a carb like how lowrange sells them what carb do i need to look at getting? any suggestions?
1993 4door Suzuki Sidekick JX
Re: what harley carb do I get?
« Reply #1 on: January 18, 2011, 02:20:46 PM »
You'll want to get the late model CV ( constanty velocity ) carb and make sure you get the choke cable assembly with it or you'll have to buy one from the HD dealer. HD = hundred dollars!
Offline Dimitros
  • 75
« Reply #2 on: January 19, 2011, 05:57:26 AM »
I'd go ahead and find some late model 44mm "Screaming Eagle" CV carb. 44mm is more than enough for stock engine and if you'll happen to build your engine once then you'll have some potential with bigger bore carb. If going to be stockish than 40mm is OK.
95 Samurai, 1.3, high comp.pistons, ported/grinded head, 1.6 valves, bored intake, Solex carb, K&N air, MSD Coil-Blaster+MSD 8.5 wires+Denso Iridium IW16 plugs, Calmini Tri-Y heder, Cherry-Bomb+Bosal custom exhaust, GRS II 4.89 T-case, 3.92:1 R&Ps, Calmini 3.5" susp., 30" BFG ATs, AVM 538 hubs...
  • 913
« Reply #3 on: January 19, 2011, 05:59:50 AM »
thanks guys im going to get on ebay this afternoon and try to find those. I appreciate the help.
« Reply #4 on: January 19, 2011, 11:16:55 AM »
Personally I'd go for the 44mm, thats about the same size as the stock 1.6 throttle body and the size that is commonly used for replacement carbs for the 1.3 here in the UK.
Offline Dimitros
  • 75
« Reply #5 on: January 20, 2011, 10:59:59 AM »
2 Rhinoman
Are those 44mm CVs expensive in UK?
Offline yzf438
  • 94
« Reply #6 on: January 20, 2011, 07:47:04 PM »
I hear the myside kit really brings the 1.3 to life.  anyone run that set up know?
Offline Dimitros
  • 75
« Reply #7 on: January 21, 2011, 09:58:34 AM »
How can you ask such question living in US, where you can get those carbs from "first hands"? There are plenty of people run CV setups in US.
Offline yzf438
  • 94
« Reply #8 on: January 30, 2011, 08:38:13 PM »
gee sorry  wondered before I did it
  • 913
« Reply #9 on: January 30, 2011, 08:41:10 PM »
just give dan at lowrange a call and talk to him. he has the stock 1.3 with a myside and the 44mm carb and really likes it himself which is the reason why im really getting one.
Offline yzf438
  • 94
« Reply #10 on: January 30, 2011, 09:26:31 PM »
put my harley carb on today.  good low end and midrange  high rpm about the same.  made a nice diff in driveability.
made my own adapter. ported my intake. works very well. build a plate to put my weber style aircleaner on.
« Reply #11 on: January 31, 2011, 10:50:27 AM »
Nice work.  Do you have any pictures of how you did the adapter?
Offline yzf438
  • 94
« Reply #12 on: January 31, 2011, 08:58:03 PM »
used the gasket for a pattern flat piece of aluminum. drilled out the holes and a hole saw for the carb.  matched the back up the weber up and mounted it on the plate.  left the aluminum long and ran some braces down to the fender for support. works good
  • 913
« Reply #13 on: February 02, 2011, 02:05:08 PM »
got the myside1 kit now I need to slap it on and hope I follow the directions good.
