Resetting clutch pedal arm
  • 3123 Views
Offline Rez Zuki 87
  • 21
« on: January 22, 2011, 03:31:08 PM »
I finally got a new clutch pedal arm after I stripped the last one.  I need help in resetting the arm.  I have both Haynes and Chilton's repair manuals and they do not have anything on it.  Once I set the pedal height, do I set the arm straight up or is it set forward or backward?
A couple of more questions.  There is a switch in front of the clutch pedal and it has been disconnected - what is this switch for?  The tab that the switch was bolted to was bent back, I guess I probably bent it when the arm was stripped.  The teeth on the pedal are stripped where the old arm was bolted to it.  Can I bolt the new arm back to the pedal or would it be best to get a new pedal, too?
Thanks for any info you can give me.
Owner of a 87 Sami.
Don't call me crazy.......it drives me nuts.
Offline ack
  • 1659
  • Professional askhole
    • Ack's FAQ
Re: Resetting clutch pedal arm
« Reply #1 on: January 22, 2011, 05:32:24 PM »
The switch is there as a safety feature.
It forces the driver to depress the clutch pedal - disengaging the engine from the transmission - during start-up.  It is wired in series with the starter solenoid circuit.
It's your choice if you want to replace the switch or leave it bypassed.
Ack
Offline ranger88den
  • 279
« Reply #2 on: January 24, 2011, 12:57:52 PM »
« Reply #3 on: January 24, 2011, 03:53:42 PM »
There are alignment dots on the arm and shaft.  Line them up, when you put the arm on, then adjust the pedal height.
Offline Rez Zuki 87
  • 21
« Reply #4 on: February 05, 2011, 04:00:30 PM »
I finally replaced the the pedal arm today, the clutch engagement is just like a new car.
Thanks for all the tips and help.
Owner of a 87 Sami.
Offline ranger88den
  • 279
« Reply #5 on: February 06, 2011, 11:46:55 AM »
I was fortunate last week; got a backup pedal, plastic bushings & lever for $6.50 at the pick n pull.
