ome springs
  • 2790 Views
Offline inchaos10
  • 162
ome springs
« on: January 26, 2011, 06:54:44 PM »
whats the best ome spring to use with the calmini lift.
Offline Jluck
  • 1389
  • 40
Re: ome springs
« Reply #1 on: January 26, 2011, 08:19:45 PM »
Im guessing your lifting a Lamborghini or maybe a Yugo? more info please ;)
Offline lv2fsh
  • 312
  • 19
Re: ome springs
« Reply #2 on: January 26, 2011, 09:11:18 PM »
On a Sammy I would use the medium springs. That's what I have on mine. With a Calmini SR
Offline inchaos10
  • 162
Re: ome springs
« Reply #3 on: January 27, 2011, 03:51:55 AM »
 ::) my bad. its a 90 tracker. im going tobe buying a front bumber and winch for the front very soon too.
Re: ome springs
« Reply #4 on: January 27, 2011, 10:22:41 AM »
I love this picture. That is life at its simplest and best.
Beware of the Jeep thing, it makes it burn when you pee!!!!
Re: ome springs
« Reply #5 on: January 27, 2011, 12:42:57 PM »
From my past experience with both types of coils, go with the stock Calmini coils if your adding a bumper and winch. Besides being shorter, the OME coils are softer and will sag like crazy with the additional weight of the bumper and winch. OR you can order a set of 14" 550lb coils from FOA.
Offline inchaos10
  • 162
Re: ome springs
« Reply #6 on: January 27, 2011, 01:05:36 PM »
Ok thanks for advice. it just rides like a tank and i figured it might help once i put a bumber on it. what about the back. as of right now i wont be puting a back bumber for a while.
Re: ome springs
« Reply #7 on: January 27, 2011, 08:21:41 PM »
The rear springs are a matter of how much lift and your preference for carrying capacity over ride quality. The standard rate rears are around 150lbs. They'll give a good ride with a fair carrying ability. If you need mor weight capacity in the future it's a simple matter of installing some Airlift bags in the coils later. The standard Calmini rear coils for their 3" lift are pretty good and I believe are near the same rate only longer.  Keep in mind that under most circumstances the springs will soften over time, in fact I've worn out and sagged 3 sets of front Calmini coils in 4 years of wheeling. With the added weight of a winch and steel bumper among other accessories they start out nice and firm, soften up to give great flex and a nice ride and eventually soften to the point of sagging and loosing lift. I've finally given up on them and am going to be installing a slightly heavier rate coil, 600lb and a inch longer than the Calmini's.
Offline inchaos10
  • 162
Re: ome springs
« Reply #8 on: February 03, 2011, 02:11:16 PM »
thanks alot for the informaton.
